homebuilt trailer for ultralight?
Old May 8th 04, 09:43 PM
L. Darte
Default homebuilt trailer for ultralight?
karel adams wrote:
are there any builder's sites
on the building of a trailer for an ultralight plane?
TIA,
Karel
I made one by simply building a ladder style frame using 1x3 rectangular
steel tubing and a set of wheels from Northern Tools. The deck is just
3/4" plywood. It's not enclosed, but it works just fine for moving
planes around.
Old May 8th 04, 11:30 PM
Vaughn
"L. Darte" wrote in message
planes around.
Good idea, or you could start with a used boat trailer.
Old May 9th 04, 12:17 AM
UltraJohn
Try a 3 bike motorcycle trailer. One each ramp for nose and main gear!
John
planes around.
Old May 9th 04, 02:19 AM
Rich S.
"UltraJohn" wrote in message
ink.net...
John
Try http://www.harborfreight.com/cpi/cta...emnumber=90154
Rich S.
Old May 9th 04, 04:34 PM
Wright1902Glider
Check out the "Logistics & Tour Schedule" section of my website. I started
with a 4'x8' bolt-together utility trailer from Northern Handyman (same unit as
HF sells). Upgraded to the 12" tires (a MUST). Stretched the tongue by
replacing the original with a 2"x3" 11ga. steel box beam. Added a deck made of
pressure-treated 2x4's covered in 3/4" pressure-treated plywood. Steel
corner-braces, steel screws, and PL 400 throughout. Tubular steel bracing from
the beam to the deck at every joist. Covered all of this with steel studs, 24"
on center, except for the first and last which are wood 2x4's. Covered the
studs with 25ga. galvanized v-seam roofing pannels. Edged and trimed out
everything using 90-degree galvanized roof flashing. The door is framed with
1x4's covered with 25ga. pannels and edged with alum. carpet edging. All steel
pannels are screwed on using neoprene-washer screws. The overall dememsions
are 23' long, 48" wide, 7'8" high, 65" track, approx 950lbs. empty. The
interior is a 45-degree v-nose, 21'6" long (18'6" w/o nose), 41" wide, 68 1/2"
high. This trailer works very well for transporting thin-section wings and
other lightweight bulky items. However, the axle should be located farther
forward to reduce tongue load. She is also very light, and does not like
cross-winds in excess of 15kts., especially when not hitched up. Since I park
on a slope, I keep her tied down with 640lbs. of concrete ballast.
Hope this gives you a few ideas of the possibilities,
Harry
http://hometown.aol.com/wright1902glider/airshow.html
Old May 9th 04, 07:28 PM
Rich S.
"karel adams" wrote in message
Try
Unbelievably low price for exactly the kind of trailer I meant.
Only I am afraid the UPS shipping rate from Cal. to Europe
would be somewhat prohibitive...
This certainly makes me understand why no sensible US citizen
builds his own more or less standard trailer.
If you wait until they're on sale, you can get 50 or 60 dollars off that
price. And think about it - they make them in China, include all the
hardware (some assembly required - the whole thing!) even the safety chains
and lighting kit, ship to North America, discount it on sale and still make
a profit.
I bought one just to use in the yard behind my garden tractor.
You'd think there would be somebody importing them in Europe.
Rich S.
Old May 10th 04, 10:35 PM
Peter Vergoossen
Hi Karel
I build my own trailer to move my airplane
(a Begium made "Ultracraft Calypso,)
take a look on my site:
http://home.hetnet.nl/~ptr008/trailer.htm
contact me, for plans!!
greetings, Peter Vergoossen
chains
make
a profit.
Rich S.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
