Akaflieg Karlsruhe AK-X
Old January 27th 16, 11:28 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Akaflieg Karlsruhe AK-X
Has anyone seen the Akaflieg Karlsruhe AK-X photos. They have flown a scale model and it looks very interesting. Wonder how it will compare to "traditional designs"? If it proformed as well or better than moe traditional design I would purchase one.
Old January 27th 16, 11:46 PM posted to rec.aviation.soaring
Glidingstuff[_2_]
From the website
"The time has come, after years of advanced development, testing, evaluation of concepts, construction of models, discarding and regenerating ideas the AK-X project is rising to a new level: We build the man-carrying flying wing of 15m glider racing class!"
https://akaflieg-karlsruhe.de/2016/0...g-flugzeugbau/
DG have started making the full size molds for them on their CNC machine.
Looks interesting,
Paul
Old January 28th 16, 01:50 AM posted to rec.aviation.soaring
Craig Funston
On Wednesday, January 27, 2016 at 2:46:10 PM UTC-8, Glidingstuff wrote:
From the website
Looks interesting,
Paul
Interesting project. I remember seeing some interesting flutter modes on the similar SB-13.
Old January 29th 16, 04:43 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Any idea what happened to the SB-13? How did it fly, what was it's performance...?
Old January 29th 16, 04:56 PM posted to rec.aviation.soaring
Dan Daly[_2_]
https://en.wikipedia.org/wiki/Akafli...ig_SB-13_Arcus
Old January 29th 16, 08:34 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I did see this, plus the short write up at Deutsches Museum Flugwerft web site. Was looking for someone with personal knowledge of this program or a technical write up of the program.
Old January 29th 16, 10:52 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
performance...?
Its also covered pretty well, with 3-view drawings, in Martin Simon's
book "Sailplanes 1965-2000".
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 30th 16, 12:39 AM posted to rec.aviation.soaring
Paul T[_4_]
If you have FSX or FS2004 you can also fly the SB13. Download he
http://simviation.com/1/browse-Glide...tralites-130-5
Seem to remember reading the SB13 was fairly tricky to fly hence it's
early retirement, and the performance was somewhat disappointing.
Old January 30th 16, 03:06 AM posted to rec.aviation.soaring
http://simviation.com/1/browse-Glide...tralites-130-5 Seem to
remember reading the SB13 was fairly tricky to fly hence it's early
Yes, indeed. The students spend 6 years working on a 1/3 scale RC model
and building it, followed by another 2 years making modifications and
retesting the aircraft, but they found that it remained tricky to fly
(stalls with a rear CG usually resulted in a spin and stalls with a
forward CG resulting in the glider 'pecking'. Unless spin recoveries were
very precise the glider often flicked into the opposite spin instead of
recovering. Its behavior on tow was diabolical, it was very tricky to fly
and, as its performance was no better than contemporary Standard Class
gliders they gave it up as a bad job and put it in a museum.
'pecking' was a large amplitude, rapid pitching cycle whose causes and
mitigation were never understood.
FWIW this is a rapid summary of the two page description in "Sailplanes
1965-2000", which also includes an excellent colour photo and a full
page, dimensioned 3-view drawing of the SB-13.
org |
Old January 30th 16, 12:13 PM posted to rec.aviation.soaring
Andreas Maurer
On Sat, 30 Jan 2016 02:06:21 -0000 (UTC), Martin Gregorie
.... and here are a couple of videos that illustrate some of the major
problems:
First flight:
https://www.youtube.com/watch?v=GY6FJZF-hS4
First (and only) winch launch attempt:
https://www.youtube.com/watch?v=WqlYORF0-oQ
Note the nose gear, and learn some German curses.
Cheers
Andreas
