Plans Built Glider
Old September 6th 03, 09:27 PM
Jim Culp
Default Plans Built Glider
Hello Curt,
The Sailplane Homebuilders Assn of
Soaring Society of America is a natural for you, as
is
Vintage Sailplane Association.
Goto
http://www.sailplanehomebuilders.com
http://www.vintagesailplane.org
http://home.earthlink.net/~raulb/
http://vintagesailplanes.de/Ka8.htm
Harken to what I have to tell you, as follows:
Let me recommend to you a wonderful classic design,
the Schleicher Ka8B.
Get one and keep it flying.
They are superb.
They are resellable. You will not be disappointed.
You may find at least one K8 for sale now on tim mara's
Wingsandwheels.com website,
under used sailplanes for sale.
They appear from time to time advertised in Soaring
magazine and the SSA webite classifieds.
Prices of these sturdy robust yet nimble 15 meter span
classics of great fame and superb flying ability, with
instruments and trailer, range about $5800-$8000 .
Go for it. You can from time to time satisfy your
need and desire to build by maintaining, recovering,
or trailer building.
In the meantime, gain the appreciation of such a fine
glider by flying it. You will find ways to stay busy
on tasks you set for yourself.
Wings and control surfaces are wood, stick and gusset,
with aircraft fabric cover.
The glider is Aircraft Type Certificated. Single seater.
Generally they are licensed Standard Airworthiness
Certificate in US. Most here were factory built in
Germany, tho a few came as kits. Most are ATC STD
Airworthiness. Many clubs used them and many were and
are privately owned.
K8s, they are quite good for flying the FAI Silver
C and Gold C badges without problems. I did my Silver
C in one, and went for badge legs of the Gold C as
well.
Fuselage is robust steel tube, its shape is fabric
covered and it has a fiberglas nose cone;
horizontal tail is wood and fabric
and vertical fin and rudder being wood or wood and
fabric.
They are fixed landing gear with wheel and a nose
skid plus a tail skid. Assembly and disassembly
is easy and quick. These gliders have nose hook and
CG hook. They can be autotowed, winch launched, bungee
launched (assuming you have a suitable launch site),
or aerotowed.
Get one with an enclosed trailer, or build that yourself...ENCLOSE
D TRAILER IS IMPORTANT. You must have that.
This design is one I have flown much and I was involved
in wing recover, stick and gusset reglues inside wing,
and other maintenance. I loved it. The design is
by one of the great glider companies of the world Alexander
Schleicher Segelflugzeugbau.
Truly, I hope you will get one and keep it flying well
I will hope to hear from you on it and your badge
accomplishments with it. Feel free to call me anytime.
Dancing on clouds,
Keep it up!
Jim Culp USA
GatorCity Florida
Std Libelle
Old September 7th 03, 10:14 AM
Robin Birch
Hi There,
Would completely agree with what Jim says. However I would say that if
you are good with wood and want an all wood machine then you could also
get a Ka6CR or Ka6E. These are all wood (give or take the odd metal
bracket). Made by the same people as Ka8s and are much better gliders.
Not to do Ka8s down as I love them and nearly bought one myself a couple
of years ago.
Again, get one that needs a refurbish and do it yourself. It'll get you
used to the "aviation way of doing things".
Ka6s are 15 metre, fuselage is plywood with wood frames and stingers.
Wings, tail plane and fin are all wood. CR is normal tail plane and
elevator, E is an all flying tail and I think a slightly improved wing
section. The E is the higher performance model.
Ka6s were described by a bloke I once met as the nearest thing to
strapping wings on your back and jumping into the air. I agree, lovely
planes, easy to fly and very very good value. One at our club regularly
does 300s.
Again, a classic design, easily re-sellable, there are higher
performance wood designs but not many (the SHK comes to mind but is a
more complex machine with its V tail).
What ever you do good luck. Building a powered craft or a glider is
something I've always wanted to do but never had the time or space.
Robin Birch
Astir CS77
Cirencester UK
In message , Jim Culp
writes
Hello Curt,
is
Goto
They are superb.
well.
fabric.
or aerotowed.
Dancing on clouds,
Keep it up!
Jim Culp USA
GatorCity Florida
Std Libelle
Robin Birch
Old September 7th 03, 08:16 PM
Lennie the Lurker
Jim Culp wrote in message ...
Hello Curt,
is
Goto
I agree with this.
I disagree with this, you have a woodworker that wants to build a
plane from scratch, not a backyard mechanic that wants to restore a
hacked out piece of ****. Your advise is useless, culp, but why did I
expect otherwise. It's apparent that the concept of wanting to build
something with your own hands is one you've never become aquainted
with.
Woodstock plans are still available, and for a fun ship, there isn't a
damn thing wrong with it except for the field snobs.
Old September 7th 03, 09:46 PM
Eggs
Hold on there big fella!
I appreciate everyone's opinion. I might build, I might fix up, I might
forget the whole thing, but let's not get nasty with one another.
I thank one and all for their thoughtful advice and look forward to further
converstations and insight.
Take care.
Curt
Old September 8th 03, 03:17 AM
Steve
Take care.
Curt
If you choose to fix up, I have two wrecked K-8s you could choose
from. One, built from a Schempp-Hirth made kit, has a broken right
wing. Included with this is a fairly complete set of drawings and a
damaged ASK-14 wing from which the wood to do the spar repair can be
obtained. The other, made originally by Schleicher, landed in some
trees, trying to get back to the home field. No main spar damage on
this one, but lots of leading edge damage to one wing, a little to the
other, and lots of bent tubes in the nose. One factory trailer is
available, but you have to buy a glider project to get the trailer.
First and foremost is get in the air. Personally owned, club, leased,
or whatever. Then, if you want a project, find one that is to your
liking and enjoy the time spent working on it.
Steve Leonard
Owner, Steve's Aircraft Supply and Salvage Yard (SASSY!)
Accumulating broken gliders since 1990.
Old September 8th 03, 11:14 AM
Chris Reed
Jim is quite right that the K8 is a nice glider of its period. When I began
flying 7 years ago my club in the UK had a K8 as the first single seater,
and it was known as the "Wooden Parachute" because it was easy to fly,
robust, and had no vicious habits.
If you decide to rebuild one with a view to flying it long-term, I think the
main consideration is the kind of flying you want to do. For XC flying the
biggest drawback of the K8 is that it has very poor penetration into wind.
The report from the UK Juniors competition this year gave one's experience
of a competition finish - "A K8 is the most efficient machine for turning
height into noise". Many pilots have flown Gold distance in a K8, but the
skill level required is very high - miss out on just one thermal by going to
the wrong cloud and you could be on the ground (in the UK anyway). My plans
for next year are Gold attempts in an Open Cirrus - if I get really good, in
a few years time I might try in a K8.
But for local soaring or short XC on light wind days, a K8 would be a
pleasure to fly. My club's K8 is nostagically missed, though I think that if
we bought another one it would be used far less than the glass single
seaters.
"Jim Culp" wrote in message
They are superb.
Sport Pilot - School Won't Offer Gary G Piloting 38 February 16th 05 11:41 AM
want to trade 601 plans for 701 plans [email protected] Home Built 0 January 27th 05 08:50 PM
Plans Built Glider? Eggs Soaring 3 September 6th 03 11:21 PM
Restricting Glider Ops at Public Arpt. rjciii Soaring 36 August 25th 03 05:50 PM
