Foam ?
Old June 5th 04, 05:18 AM
Neil
Default Foam ?
Ok, I am restoring a hovercraft, not a airplane, but the techniques may be
the same....I hope.
I have to bond foam into a existing fibreglass shell, to support the
fibreglass, and to make the unit float in water. The original builder used
canned foam, with pretty poor results. Any ideas?
Thanks in advance
Kim
Old June 14th 04, 02:54 PM
I.B. Phuckenutts
In article , Richard Riley wrote:
You know, as I think about it, for your purpose a 2 part expanding
foam is probably better.
http://www.aircraftspruce.com/catalo...es/x30foam.php
Clean the fiberglass thoroughly. Then pour it on the inside of your
fiberglass and brush it around quickly, before it starts foaming
(you'll only have a few seconds) and it will bond well to the
fiberglass.
No, no, no, you dunno wanna do dat! The two part foam will absorb
and trap water (holding it forever). Been derr don dat!
Old June 14th 04, 05:10 PM
Evan Carew
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
[snip]
Gaak!! Your're right. But I've seen a closed cell do-it-at-home
expanding foam somewhere. If I can just remember where. Damned CRAFT
disease.
Isn't that what A.S. sells for use in making aircraft floats & boats
sinkproof? URL: http://www.aircraftspruce.com/catalo...es/x30foam.php
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAzb/Uoo/Prlj9GScRAk4zAJ4lbsUEr1h4Zfo5JEj3mUmwx1PipwCfZtv6
w4FNHJLOkoSw5mTo7keUQo0=
=POet
-----END PGP SIGNATURE-----
Question about epoxy resin chemistry.. Chris Home Built 26 April 15th 04 01:55 AM
blue foam & cutting it Richard Riley Home Built 6 November 24th 03 02:53 PM
Foam BD5ER Home Built 17 September 20th 03 05:07 PM
blue foam, pink foam, yellow foam? Corrie Home Built 26 September 1st 03 06:01 PM
Is there a trick for installing a Tinnerman spring nut? Michael Horowitz Home Built 9 July 14th 03 05:01 AM
