Cobra trailer fittings for different glider makes & models
Old September 23rd 03, 04:06 AM
John W
Default Cobra trailer fittings for different glider makes & models
In general, how different are the fittings in a Cobra trailer for
different makes and models of gliders, 15M and Standard class?
For example, what changes would be required to put an ASW20 into an
ASW28, or Discus, or Ventus rigged Cobra trailer?
Thanks for any advice,
John
Old September 23rd 03, 05:31 AM
JJ Sinclair
John,
I have done what your proposing a couple of times and for the most part, it is
straight forward. All the fittings are adjustable and everything should work
out fine. I would check the height of the wing dolly to see if it is correct
for the new wing. All the stops are adjustable and so is the nose cone, both
height and length.You may have to move the tail wheel (skid) bracket in the
floor.Give me a shout, if you run into trouble.
JJ Sinclair
Old September 24th 03, 01:56 AM
BTIZ
Also check the wing chords. Typically std. class gliders have a wider
chord
than 15M ships.
Guy Byars
I thought standard class was 15m...
Old September 24th 03, 04:15 AM
ADP
Let's see, chord = span? I don't think so.
ADP
"BTIZ" wrote in message
news45cb.1543$La.1134@fed1read02...
chord
than 15M ships.
Guy Byars
Old September 24th 03, 04:21 PM
Bob Kuykendall
Oh aye. But the front running 15-Meter ships tend to have around 10m^2
of wing, while the Standard contenders generally have about 10.5m^2.
And since they are both span-limited to 15 meters, the extra area has
to come from more chord.
Bob K.
FS: Cobra Trailer Ed Byars Soaring 0 September 22nd 03 05:47 PM
I wish I'd never got into this... Kevin Neave Soaring 32 September 19th 03 01:18 PM
Need (glider&) trailer transport - Sante Fe, NM > Santa Cruz, CA, late Aug Eric Soaring 1 August 8th 03 04:21 PM
Glider trailer towing Jeff Landfield Soaring 0 July 21st 03 05:25 AM
