Plasma Ropes ----- Help
Old September 30th 03, 10:29 AM
Dave Martin
Default Plasma Ropes ----- Help
To any club using plasma ropes in place of steel.
Having read the benefits of this type of rope, several
UK clubs are interested in its use. One major obstacle
to this, is cutting it during a launch, in the event
of an emergency
So far the best methods appear to be an axe an anvil
type cutter.
Any slight imperfections on scissor, guillotine and
even the axe methods of cutting mean the rope does
not get completely cut through. Even though the equipment
cuts steel succesfully.
Various methods such as hot wire and laser beams have
been suggested, but with the way members treat club
equipment I suspect the life of such things would be
minimal.
What emergency cutting methods for plasma rope do those
who use it employ?
Thanks in anticipation
Dave Martin
Old September 30th 03, 10:54 AM
Sf760
I understand that Skylaunch have developed a guillotine that cuts it very
nicely.
Old September 30th 03, 03:10 PM
Bill Daniels
"Dave Martin" wrote in message
minimal.
Dave Martin
Why should a hot blade be fragile? The winch engine starting battery has a
lot of power to heat a robust blade very quickly. You only need to get the
blade to Spectra's 265F melting point - far below the blades melting point.
I would just mount the blade in a strong frame near the path of the rope and
push the rope against the stationary hot blade with a rubber block. If well
built, it should last nearly forever.
Bill Daniels
Old September 30th 03, 07:03 PM
tango4
Surely a scissor type gulliotine would be more effective
Ian
of an emergency
type cutter.
minimal.
who use it employ?
Dave Martin
Old September 30th 03, 09:05 PM
Sf760
Tried that, with a shiny new freshly sharpened scissor type guillotine, and it
didn't cut it, this stuff has very fine fibres which just bent around the
corners. even using heat-shrink sleeving to simulate a plastic coating, we got
the same results, you simply could not be sure of cutting the rope.
Old September 30th 03, 11:08 PM
Bob Johnson
Dave --
Just thinking out loud here, always dangerous: nail guns, either
percussive, powered with shotgun shell or the like, or pneumatic with
air cylinder. Sorry, no blueprints available. Replace nail with blade
would be good.
Wondering about guillotines in general, I know it's always good to have
one, but has anyone in earshot actually used one? If so, what were the
circumstances, line running or still, weak link or no, spring, gravity
or muscle powered, radios or how did you know and like that.
Bob Johnson
of an emergency
type cutter.
minimal.
who use it employ?
Dave Martin
Old October 1st 03, 12:07 AM
Bill Higdon
How about a chunk of "Det. cord" in a circle or two with the Plasma rope
running through the center. Use a "pull" type of initiator to trigger
the Det. cord.
Bill Higdon
Bill Daniels wrote:
Bob, you need to get some of this stuff and play with it. It doesn't cut
the way metal does - in fact, it's the preferred body armor for knives and
penetrating weapons.
The people who work with this stuff all the time use electrically heated hot
blades. They cut through it like it isn't even there.
Bill Daniels
"Bob Kuykendall" wrote in message
om...
quickly.
I would definitely look askance at a system that required electricity
to cut the cable, and I think that most certification authorities
might also. I prefer my emergency systems to be powered by gravity,
strong springs, or if necessary percussion-lit pyrotechnics.
melting point.
I'd tend to believe that you need to heat the blade to about twice or
three times that - to account for the fact that you might be trying to
cut the cable as it is running in or out, and so the blade is
transferring heat to a pretty large volume of cable. Also, you'd want
to cut the cable as fast as possible. This might be a neat idea if it
were heated by exhaust from the winch engine...
My preference would be for a sharp guillotine, for which the blade can
pivot slightly to account for minor misalignments between the arm axis
and the plane of the anvil. I'd try an anvil made of a 2" by 6" piece
of MDF (medium density fiberboard) to be renewed after each slice. In
testing, I'd look for 25 cuts out of 25 tries.
Just my few ill-formed thoughts on the matter.
Thanks, and best regards to all
Bob K.
Old October 1st 03, 12:23 AM
W.J. \(Bill\) Dean \(U.K.\).
There was a fatal accident in the U.K. when the glider being launched got
the launching wire over a wing. The guillotine was fired by the winch
driver, but failed to cut the wire (which was of course being pulled out by
the glider). It is not certain that cutting the wire would have saved the
pilot, but he had little chance with it uncut.
As a consequence of this accident we are very aware in the U.K. of the
necessity for a reliable method of cutting the cable. The guillotine was
re-designed, and they are now regularly serviced and tested in accordance
with a laid-down schedule.
So the answers to your question are; yes, the winch driver could see the
problem, the guillotine failed to cut the wire.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"Bob Johnson" wrote in message
snip
Bob Johnson
Plasma Reduces Jet Noise (Turbines?) sanman Home Built 1 June 27th 04 01:45 AM
Plasma Reduces Jet Noise (Turbines?) sanman Rotorcraft 1 June 27th 04 01:45 AM
Using Plasma Rope For Winch Tows Craig Freeman Soaring 56 August 24th 03 11:55 PM
Winching: Steel vs. Plasma Bob Johnson Soaring 10 August 12th 03 06:41 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 02:37 AM
