Removing Old Contest Numbers
Old November 23rd 03, 06:19 PM
Milan Air
Default Removing Old Contest Numbers
Hi everyone,
some time ago I read a very detailed article on removing old contest
numbers from a fiberglass glider. Now that I need it I can't locate
it.
Does anyone know where that article was posted ?
Thanks for your inputs and help.
Best regards,
Milan.
Old November 23rd 03, 09:26 PM
Judy Ruprecht
At 17:30 23 November 2003, Milan Air asked for help
finding an article on removing old contest numbers...
RAS readers were kind enough to tackle this and a related
question about rubbing compound back on March 20,2003.
Searching on 'contest number,' the rec.aviation.soaring
archive link on the Glider Pilot Network can take you
to these suggestions.
FWIW: Lacquer thinner worked for me, so although I
did not find Gary Evans sanding advice necessary, I
firmly believe the case of beer he suggested is an
integral part of any project.... asuming, of course,
it's reserved for the post-project celebration.
Judy
(hic!)
Old November 24th 03, 08:08 PM
Wallace Berry
Judy
(hic!)
I've removed factory painted on numbers from a couple of Libelles.
Laquer thinner works, but it is actually the acetone component of laquer
thinner that does the job. Straight acetone actually works a lot better
than the laquer thinner and is cheaper and less toxic.
Old November 24th 03, 09:12 PM
Greg Arnold
I recently removed contest numbers. First I used acetone, which worked
OK. Then I used lacquer thinner, which worked better.
Judy
(hic!)
Old November 24th 03, 10:26 PM
Nolaminar
There are different grades of lacquer thinner.
The general hardware store variety is not as strong as available from paint
stores.
Probably same is true with acetone.
If the numbers are painted on, acetone works well.
Vinyl can peel off if it is less than a year old. If older, they can
sometimes be warmed and softened with hairdryer and then peeled.
GA
GA
Old November 25th 03, 01:59 AM
Milan Air
Wallace Berry wrote in message ...
Thank You for your reply and advice. This is my first time using
Google and I just realized that I can do a search per various topicks.
As far as the beer goes I prefer the good European stuff
Cheers,
Milan.
Judy
(hic!)
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 06:18 AM
History of Contest Scoring Bill Feldbaumer Soaring 8 October 8th 03 03:14 PM
1930s Navy side numbers. JDupre5762 Naval Aviation 3 September 24th 03 08:51 PM
Region 6 South Contest (USA) BMacLean Soaring 0 September 1st 03 09:37 PM
2003 Air Sailing Contest pre-report synopsis Jim Price Soaring 0 July 10th 03 11:19 PM
