Empty/Gross weight Vs. Max. Pilot weight
Old January 3rd 04, 05:49 PM
Flyhighdave
Default Empty/Gross weight Vs. Max. Pilot weight
Hi All!
I'm confused by the weight restrictions on most gliders.
As an example the Lak-12 specs show the following:
Empty weight: 794lbs.
Gross weight: 1433lbs.
Payload: 693lbs.
Max. Water 416lbs.
Max. Pilot: 242lbs.(110KG)
Why is the pilot weight restricted to a max. of 242lbs? It seems to me like the
difference between the empty & gross weights could be made up of any
combination of pilot, equipment & ballast as long as the gross weight is not
exceeded & the C.G. remains within limits. What am I not understanding here?
As any of you know who have read my numerous recent questions to this group I
am a new and BIG pilot trying to figure out which ships will work for me &
learn a little more about this endeavor. I could weigh as much as 250lbs fully
equipped in the winter. That appears to exceed the limits of almost all
gliders.
Again the generous information that I've gotten from you all is just great!
Thanks!
David Roth
Old January 3rd 04, 06:00 PM
Ray Payne
maybe max weight of none lifting parts
Old January 3rd 04, 08:41 PM
Eric Greenwell
Flyhighdave wrote:
Hi All!
Payload: 693lbs.
Max. Water 416lbs.
The difference is where the weight is carried:
- in the wings, it reduces the load on the wing spars, especially at the
root. That's why it's carried there.
- in the cockpit, it increases the load on the wig spares, especially at
the root. This is why there is a "non-lifting" parts (basically, the
fuselage) load limit, in addition to an overall limit.
The actual limit may also be set by things like seat and belt attachment
strength, not just the wing strength. You don't know, unless the
designer tells you.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old January 3rd 04, 10:24 PM
F.L. Whiteley
See JAR 22
http://www.jaa.nl/section1/jars/445499.pdf
Sections 22.25 and 22.785
for details.
110kg is minimum maximum under the above, but also an upper limit in many
cases. Older sailplanes built under OSTIV may have all a max weight of
non-flying parts that allows 250lb+ pilot weights and a safe CG range far
above that, like 350lbs.
Frank Whiteley
"Flyhighdave" wrote in message
Hi All!
Payload: 693lbs.
Max. Water 416lbs.
like the
not
here?
group I
fully
gliders.
great!
Thanks!
David Roth
Old January 3rd 04, 10:43 PM
Walter Kronester
Dear David,
the reason for the max pilot weight of 110 kg is rather simple: The (old)
European certification specifications for gliders, JAR22,
request, that the center of gravity stays within its limits at pilot weights
from 70 kg to 110 kg with parachute (!!) without
ballast, and that at least a pilot of 110 kg must be carried (see
JAR22.23-22.25). For a two seater, the value is 180 kg. So other
calculations, e.g. seat strength, belt fixpoints and so on are based on this
minimum value for the max. pilot weight of 110 kg, and
this 110 kg are printed in the glider specs. This has nothing to do with the
max. weight of 'not lifting parts' or with the payload.
So for pilots above 110 kg, it will not be easy to find a glider, which they
can fly legally.
Anyhow, you should contact the manufacturer of your glider. It might well be
he knows a solution.
Best regards
Walter
Old January 4th 04, 05:05 AM
BTIZ
Why is pilot weight restricted?.... because that is the weight limit it was
certified to.
BT
Hi All!
Payload: 693lbs.
Max. Water 416lbs.
like the
not
here?
group I
fully
gliders.
great!
Thanks!
David Roth
Old January 12th 04, 07:14 AM
Bruce Hoult
(Flyhighdave) wrote:
Hi All!
Payload: 693lbs.
Max. Water 416lbs.
me like the difference between the empty & gross weights could be
made up of any combination of pilot, equipment & ballast as long as
the gross weight is not exceeded & the C.G. remains within limits.
- max weight of non-lifting parts (think: strength of the fuselage
mountings)
- seat and seatbelt mounting point strength
- C of G out of limits, possibly meaning not enough up elevator
available at low speeds (e.g. landing round-out)
group I am a new and BIG pilot trying to figure out which ships will
work for me & learn a little more about this endeavor. I could weigh
as much as 250lbs fully equipped in the winter. That appears to
exceed the limits of almost all gliders.
The day I'm 242 lbs, including parachute, will be a minor miracle.
Right now I'm 260. Several months ago, around the beginning of spring,
I was over 270. Several years ago when I was dotcommed for a while and
bicycled 30 - 50 km every day during a Chicago summer I got down to
about 250 briefly.
I've flown quite a few gliders, at quite a few places in NZ and the USA,
and no one has *ever* suggested that I shouldn't be flying their gliders
due to weight. Sometimes I've had a conversation with an engineer or
instructor and we've agreed that I'll mentally knock 5 or 10 knots off
the placarded rough air/manouvering speeds and keep the G loading down.
I do that anyway. It's probably not necessary.
Just because it's easy to do, here's a logbook dump of the types I've
flown. Not a lot of experience, I know, but more than zero...
Glider Type Flights Total PIC Avg
Club Libelle 36 56:55 56:55 95
Blanik 110 46:56 27:38 26
Janus 43 36:55 30:02 52
Ka6CR 21 26:26 26:26 76
PW-5 19 20:04 20:04 63
Twin Astir 27 14:42 12:08 33
Std Libelle 9 9:32 9:32 64
Grob 103 3 3:13 3:13 64
ASK21 6 2:42 2:42 27
Ka7 16 1:52 0:14 7
ASK13 3 1:32 1:15 31
Duo Discus 1 1:07 0:00 67
Puchacz 1 1:02 0:00 62
T53 1 0:37 0:00 37
Phoebus C 1 0:33 0:33 33
Pirat 1 0:19 0:19 19
I haven't had problems with any of the above types, although I'm
probably over the placarded weight for all of them (and some, such as
the K6 and the Std Libelle are a bit of a squeeze).
People flying marginal powered aircraft are, rightly, quite a bit more
concerned about weights. Put full tanks and two big people in a Cessna
152 and it probably won't climb at *all*.
-- Bruce
Old January 12th 04, 12:36 PM
Robert John
Bruce,
I don't know what the insurance arrangements are in
the places you fly, but what would worry me here in
the UK is this:
Flight outside placarded limits is outside CofA.
Flight without CofA is uninsured.
Are you sure you're covered in the event of a prang?
It's an easy get-out for an insurance company faced
with a potentially big claim.
Rob
Hi All!
Payload: 693lbs.
Max. Water 416lbs.
It seems to
could be
as long as
within limits.
of the fuselage
mountings)
up elevator
questions to this
which ships will
I could weigh
appears to
minor miracle.
for a while and
I got down to
about 250 briefly.
in NZ and the USA,
an engineer or
5 or 10 knots off
the G loading down.
of the types I've
zero...
Ka7 16 1:52 0:14 7
T53 1 0:37 0:00 37
although I'm
(and some, such as
quite a bit more
people in a Cessna
-- Bruce
Old January 13th 04, 02:10 AM
BTIZ
"Robert John" wrote in
message ...
Bruce,
the UK is this:
Rob
I believe the same would apply here in the USofA..
obvious flight over max weight limitations.. no insurance coverage..
don't forget that some of those gliders also have, max weight for non
lifting parts
you may be within the Max GW, but not the max of the non lifting parts
BT
Old January 13th 04, 02:35 PM
Andy Durbin
Robert John wrote in message ...
Bruce,
the UK is this:
Rob
NTSB database is well populated with aircraft accident reports that
list flying over max certificated gross weight as a contributing, or
primary, accident cause.
Can anyone cite a single case where insurance payout was refused on
that basis.
Please note that I am NOT advocating flying over any weight limit, I
just think the "you won't be insured" argument is a bit thin.
Andy
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
RV-7a baggage area David Smith Home Built 32 December 15th 03 05:08 AM
Moving violation..NASA form? Nasir Piloting 47 November 5th 03 08:56 PM
Effect of Light Sport on General Aviation Gilan Home Built 17 September 24th 03 07:11 AM
