This Is What It Looks Like When An F-35 Refuels Right In Front Of Your Face
Old March 10th 17, 05:36 PM posted to alt.binaries.pictures.aviation
Miloch
Default This Is What It Looks Like When An F-35 Refuels Right In Front Of Your Face
http://foxtrotalpha.jalopnik.com/thi...t-i-1793139999
Most aerial refueling videos are shot through the tiny little window that the
booms use to steer a little fuel nozzle towards a thirsty aircraft. But the
KC-130 is not just a flying gas station, it’s also a fully functional cargo
plane. Which means you could throw down the ramp, and hang out the back.
The F-35 actually uses two different methods of re-fueling, depending on the
variant. The U.S. Air Force version, the F-35A, uses a big metal boom to pump
fuel directly into the fighter jet’s tanks, and which looks pretty much like
every other aerial refueling video you’ve seen. What basically happens in that
setup is that the fighter pilot flies the jet into place, and then a boom
operator uses a little joystick to make sure the nozzle gets to the right spot.
But the F-35B and C variants, used by the U.S. Marine Corps and U.S. Navy,
respectively, use a system known as “probe-and-drogue.” Instead of a big metal
pole hanging out the back of the refueling plane, a flexible hose with a
receptacle that looks like a basket hangs out the back – or from the wings –
instead. In that case, there’s no one boom operator to steer the hose. In the
F-35's case, the tanker pilot holds the plane steady, while the fighter jet
pilot deploys a probe from their own aircraft’s nose, and uses their light and
nimble jet to steer the probe into the basket.
In the case of the video up top, a Marine Corps F-35B was being refueled by a
KC-130J during an exercise last summer over Arizona. And even for all of the
drama around the F-35, it still looks neat.
Polaris refuels CF-188 - 1 attachment Andrew Chaplin Aviation Photos 0 April 17th 11 10:44 PM
The New Face Of Terrorism B-Hate-Me Aviation Photos 12 June 5th 07 01:17 AM
FAA does about-face on Age 60 issue Kingfish Piloting 4 February 3rd 07 01:19 AM
Fan Face Blockers? tffy Military Aviation 0 May 4th 04 01:00 AM
Face-recognition on UAV's Eric Moore Military Aviation 3 April 15th 04 04:18 PM
