Transponders
Old January 21st 04, 02:45 PM
Mil80C
Default Transponders
A question to you fine soaring fraternity, what would your response be to
someone who suggested that it might be feasable to run a transponder in a
glider with a pedal generator?
BEER! So much more than just a breakfast drink!
Old January 21st 04, 03:59 PM
Vaughn Simon
"Mil80C" wrote in message
A raised eyebrow, a polite silence, a glance at my wris****ch, followed
by a graceful withdrawal.
Vaughn
Old January 21st 04, 06:21 PM
Ben Flewett
Are you on drugs? This is a bad idea for so, so many
reasons. Here are a few...
1. I don't want to pedal.
2. My feet are busy operating the rudder.
3. My cockpit is a constant state of crisis, which
allows no time for pedalling.
4. I sometimes fly in airspace for hours at a time.
I resent have to move the stick for hours at a time,
let alone having to pedal for hours at a time.
5. Weight.
6. Complexity.
7. I like a simple life.
8. I don't want a bearded sandal wearer installing
weird science contraptions in my glider.
Here's an idea. Why not use a battery?
At 15:00 21 January 2004, Vaughn Simon wrote:
'Mil80C' wrote in message
your response be to
Vaughn
Old January 22nd 04, 02:06 AM
Liam Finley
"Mil80C" wrote in message ...
That's a brilliant idea.
Here's an even better one: power the transponder with a little
hamster running in a wheel connected to a generator.
Why not equip the glider with a second hamster to power a boundary
layer suction device, or perhaps an external propeller?
Old January 22nd 04, 04:50 AM
Graham Wardell
I know some pilots who would be good at it. Just connect it to their rudder
pedals!
Old January 22nd 04, 06:03 AM
BTIZ
would it then be a glider?
I wonder how much drag a RAT would create.. power all the stuff on a Ram Air
Turbine generator...
LOL
BT
Old January 22nd 04, 06:32 AM
Jack
On 04/01/21 07:45, in article
, "Mil80C"
I'd say he's noticed my rudder coordination efforts.
Jack
Old January 22nd 04, 06:35 AM
CH
and how long does the battery last?
with the transponder on?
Australia decided, that planes without a permanent source
of power on board, do not need transponders in mixed
airspace.
I would prefer, that IFR traffic out of airport airspace should
fly higher than the convection height from sunrise to sunset :-)
How's that??
Chris
"Ben Flewett" wrote in message
5. Weight.
6. Complexity.
your response be to
Vaughn
Old January 22nd 04, 06:37 AM
Mark James Boyd
Hmmm...I wonder how big solar panels would need to be to generate
the needed power. The wings have a lot of area...
They make some very thin panels, but incorporating them into the
body might be quite tricky.
How about one on the dash, or right above the pilot's
bald spot? Could give some shade too!
Old January 22nd 04, 07:17 AM
Eric Greenwell
A modern transponder like the Becker or Microaire draws about 600 ma
with an encoder. People report getting 5 and 6 hour flights on a 7
amphour battery, and still plenty of power left.
airspace.
How's that??
Chris
Aye, and that's the rub: they come down to the airport, don't they? And
the airport airspace doesn't go all the way up to 18000 here in the USA,
but only to about 10,000 or so. And the buggers don't drop down into the
top, but slide in from the side. Can you believe it?
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Non-radar transponder codes Michael Instrument Flight Rules 16 February 13th 04 02:15 PM
Dual Transponders? Scott Aron Bloom Instrument Flight Rules 17 December 14th 03 06:54 AM
Mode S Transponders - Can ATC tell the difference? Doodybutch Owning 2 August 10th 03 07:21 AM
Transponders, Radios and other avionics procurement questions Corky Scott Home Built 5 July 3rd 03 12:27 AM
