90 Degree turn while slipping
Old February 5th 04, 03:39 AM
ISoar
Default 90 Degree turn while slipping
I can't find anything in my books about how to make a 90 degree turn
(e.g., downwind to base) while in a full slip, but maybe that's
because it's so obvious. (Given my limited # hours, just because
something seems obvious to me doesn't mean I'm not going to check it
out.) I figure I'll turn with roll input, but can't picture the side
effects from doing that. If I know the side effects I can have a
chance of being ahead of the plane during the maneuver.
Anyway, is there going to be any adverse yaw from turning in this
mode? Even if there is, I don't think I can do anything about it,
but enquiring minds want to know. The other question is if the
attitude going to change as a side effect of the roll input. This
will be in a 2-33.
Thanks
Old February 5th 04, 09:17 AM
Pete Zeugma
a 90 degree turn
Funny that, but then you should take a massive pinch
of salt when you read posts about making you turns
with the rudder. If you need to side slip at all during
your downwind, base and final, best do it on the straight
parts and use proper coordinated well banked turns
between. The one thing you should always avoid getting
into is turning with excessive amounts of rudder. Why?
This is where spins develop from, because in the event
of you stalling, the likelyhood of you surviving when
low, as you would be on your base turn, or final turn
are very slim. Get into the habit of flying turns in
a coordinated manner right from the start, at all times.
the side
There are no side effects of performing a correct well
banked coordinated turn.
If you fly in a coordinated manner you dont have to
think ahead of the plane
in this mode?
any aileron input will produce adverse yaw
about it,
if you were flying coordinated turns it would not be
something you have to factor in.
absolutely. problem though with this news group, which
is ment to be a gliding news group, there are to many
power pilots preaching power techniques!
input. This
will be in a 2-33.
there will always be an attitude change in any turn.
Thanks
Old February 5th 04, 09:53 AM
Marc Ramsey
out.)
Speaking for myself, when I say I'm making a "slipping turn from base to
final", what I really mean is that I start off in a coordinated
moderately banked turn. When the nose is still pointing something like
20 to 30 degrees away from the runway, I slowly start feeding in
opposite rudder to transition into a forward slip. Adjustments are
made in yaw, pitch, and roll, to maintain a stable forward slip on the
runway heading until any excess altitude is eliminated, at which point I
transition to straight flight and a normal landing.
If this is something you haven't done, you definitely should get an
instructor to show you how, this is not something you want to be
learning on your own...
Marc
Old February 5th 04, 10:20 AM
David Hodgson
a 90 degree turn
Couldn't agree more!
What must be remembered about these sort of discussions
is there is a significant difference between 'what
can be done' and 'what should be done'
Having to use slipping to this extent to get rid of
excess height can only be the result of a very poorly
planned circuit (very tight ridge sites excepted).
Slipping can be useful to get in to a small field off
site but even then should only be required on finals.
It is far better to plan, execute, monitor and adjust
your circuit all the way round than have to take this
sort of corrective measure. Once you are in this situation
then you have severly limited your options which is
never a good idea in a glider.
Dave H
Old February 5th 04, 11:28 AM
Bert Willing
Funny thing this discussions. Slipping turns from base to final were part of
my practical exam to get my license in Germany. Well that's now 20+ years
ago, and we did that on Ka7, Ka8 and things like that.
It is coordinated flight, by the way.
Bert Willing
ASW20 "TW"
"Marc Ramsey" a écrit dans le message de
. com...
out.)
Marc
Old February 5th 04, 02:28 PM
Andy Durbin
ISoar wrote in message . ..
will be in a 2-33.
Thanks
Just roll toward the direction you want to turn. The steeper the bank
angle, the greater the turn rate. The nose will be high and outside
the turn compared with a non slipping turn.
Please do it with an instructor at altitude before you try it in the
pattern.
Andy
Old February 5th 04, 03:56 PM
Andreas Maurer
On Thu, 5 Feb 2004 11:28:19 +0100, "Bert Willing"
An approach without flaps by sideslip-only (including sideslip turn
from downwind to final) was also required during my instructor
examination. I did that in a G-103 Twin Astir, but I also saw the same
being done with an ASH-25.
Lots of fun, by the way. Nothing more thrilling than taking part in a
precision landing contest without even touching the flap lever...
Bye
Andreas
Old February 5th 04, 04:21 PM
Janos Bauer
The main difference is when you stop the sideslip with these new
composite planes. Higher speed required to maintain safe sideslip
position but these planes has no same drag in normal glide position as a
KA7 has. So expect to run much longer
/Janos
Bye
Andreas
Old February 5th 04, 04:43 PM
ISoar
On Thu, 05 Feb 2004 10:16:17 -0500, Todd Pattist
A full slipping turn
is perfectly safe and can be useful when your airbrakes are
frozen shut or when you just want a steeper approach than
normal.
I guess I should have made it clear that my need to know how to do
this was for the simulated case where the airbrakes are frozen shut.
Thanks for the tips.
Old February 5th 04, 05:05 PM
Andreas Maurer
On Thu, 05 Feb 2004 16:21:14 +0100, Janos Bauer
This is the problematic point here.
It is possible to keep the sideslip even during the flare (to increase
drag), but the lower wing tip is very close to the ground then... not
a game for a beginner.
Frankly spoken, I have no idea how a "normal" pilot without lots of
sideslip experience is going to land a glass glider safely without the
use of aibrakes.
Bye
Andreas
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
"Proceed on Course" = "Right turn approved"? Bob Chilcoat Piloting 41 July 19th 04 12:48 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 04:27 AM
Rate of turn indicator on commercial jets (Boeing / Airbus) Mark Simulators 1 November 1st 03 11:35 AM
IFR in the 1930's Rich S. Home Built 43 September 21st 03 02:03 AM
