Denso alternator connections
Old July 4th 04, 11:32 PM
Paul Lee
Default Denso alternator connections
Got a small Denso alternator with internal regulator and no wiring diagram.
The two lower of the three regulator pinouts are labeled as IG and L.
The upper is a D connection. Anybody know what the different connections
are for?
Old July 5th 04, 02:29 AM
Vaughn
Check the diagram at the bottom of this document:
http://www.f1-rocketboy.com/alternator.htm . If that is no help, do a Google
search on "Denso alternator connection diagram" that yielded 136 candidates,
including the one above.
Vaughn
"Paul Lee" wrote in message
om...
are for?
Old July 6th 04, 10:22 PM
Paul Lee
OK. I figured out the IG (ignition) and L (lamp) connectors.
And just now found that the D connector is a dummy connector
that does not do anything. The S connector in the reference
you gave has some meaning (battery Sensing). But the
D had me scratching my head.
"Vaughn" wrote in message ...
Vaughn
om...
are for?
