Devices for avoiding VNE?
Old March 29th 04, 12:53 AM
John Galloway
Default Devices for avoiding VNE?
Through the contributions to the avoiding VNE thread
runs the theme of the difficulty of avoiding overspeeding
and/or overstressing some modern designs in accidental
spin recovery. This is made more difficult than in
older composite gliders because they had a little more
drag and a little more (fortuitous) margin in the g
limits.
Is it not blindingly obvious that there is a need for
an emergency drag device that does not reduce the G
limits of gliders? Clearly if we all handled the recovery
from inadvertent spins etc perfectly all would be well
but equally clearly that does not always happen and
it is a shame to lose pilots in this situation.
As the Phoebus pilot pointed out a tail chute is ideal
for this - providing that it can be made to actuate
and jettison reliably. (I found the design used on
the Kestrel particularly good and I never once had
a failure for landing use) On the other hand they
are expensive and inconvenient to replace and there
are several ways that they can fail.
So can anyone think of a better idea than a chute?
The best I can come up with is some sort of flush
fitted rectangular-with the-long-edge-horizontal rear
hinged airbrakes (like old fashioned automobile suicide
doors) located on the fuselge sides somewhere in the
region below or below/behind the wings. If they opened
to about 45 degrees with a spring actuator (and limited
by sliding metal stays that hinge/attach to the front
of the panel and whose inner ends slid along in runners)
then they would provide a lot of drag without any deep
internal mechanism (such as wing airbrakes have).
Once they have done their job the rear end of the brakes
could be released by a spring loaded mechanism similar
to the front end so that the brakes would then instantly
spring to as position set out from and parallel to
the fuselage so that there would be very little drag
- only that provided by the stays at both ends and
the brake panels edge on to the wind. That configuration
would be good enough to fly home with. It would only
be possible to reset these brakes on the ground and
they would not replace conventional wing airbrakes
for approach control - although they could have a secondary
use for emergency approach control.
I am envisaging something the could be included in
new designs although there does not seem to be any
obvious reason why such a device could not be retrofitted
as a fairly major modification. The contours of the
brake panels would be specific to the individual fuselage
type but the mechanism could be generic. The assembly
would be fairly shallow and complete within itself
apart from e.g. a cable release attachment.
I am not advocating a technical solution to this problem
in place of spin recovery practice but I do think that
there must be something that the combined intellects
of the gliding community can come up with other than
observing that if we get into that particular overspeeding/steep
attitude condition we are stuffed.
Anyone got any simpler or better ideas? I am definitely
not an engineer.
John Galloway
Old March 29th 04, 02:02 AM
Bill Daniels
I'd vote for the tail 'chute.
It has been approved before, it has other uses than in a near Vne incident,
the modification is relatively easy and it's light weight.
True, it's not 100% reliable but neither are the personal 'chutes we wear
yet they are deemed very useful.
Bill Daniels
"John Galloway" wrote in message
limits.
not an engineer.
John Galloway
Old March 29th 04, 02:13 AM
Bill Daniels
Now I'm second thinking myself.
If the devices proposed added 20 pounds to the glider, wouldn't those same
20 pounds added as carbon fiber pultrusion rods in the spar caps increase
both the ultimate load factor and Vne enough to resolve the problem in a
better way?
Bill Daniels (again)
"Bill Daniels" wrote in message
incident,
Bill Daniels
limits.
not an engineer.
John Galloway
Old March 29th 04, 12:28 PM
John Galloway
As regards tail chutes - I personally would be very
happy indeed if I could get a new glider for my personal
use supplied with a tail chute and I have extolled
their virtues as emergency devices several times previously
on RAS. Unfortunately the fact is that there is a
history practical problems with reliability - especially
in club gliders and syndicates. (When I owned my own
Kestrel I took the chute home after each flight, repacked
it, and kept it in the airing cupboard to make sure
it was dry. The Kestrel also had an excellent spring
loaded actuator and a reliable mini-otfur type of release
for jettisoning. I was very confident in it.) Unfortunately
I just don't see tailchutes being put on to gliders
as emergency speed limiting devices partly because
the manufacturers would likely feel legally exposed
by the inclusion of such hit or miss, owner-maintenance-dependent
items for such a critical application.
I started to think about whether there could be a more
reliable hardware rather than fabric alternative device
tailored more towards emergency speed control than
approach control and the best I could come up with
was what was in in the last posting. BTW I don't think
that what I hand in mind would add anything like 20lbs
a pair to the glider weight.
My main motivation in starting this thread was to guage
and encourage the support for the inclusion of off-wing
emergency speed limiting devices and whatever turns
out to be the best option has my support. As gliders
get slippier and wings get thinner and design margins
get tighter and average pilot ages and reaction times
increase we either have to seek technical help or accept
that numbers over VNE accidents are going to increase.
Nothing will happen without recognition that there
is a need and customer demand for a solution.
John Galloway
wouldn't those same
the problem in a
better way?
'Bill Daniels' wrote in message
in a near Vne
incident,
weight.
'chutes we wear
Bill Daniels
'John Galloway' wrote in message
in
more
g
limits.
for
G
recovery
well
ideal
on
rear
opened
deep
brakes
only
secondary
fuselage
problem
that
not an engineer.
John Galloway
Old March 29th 04, 05:28 PM
303pilot
Sounds like a call to go back to an earlier 15 meter design spec that
required full speed limiting device - flaps, spoilers, brakes, chute or
combination thereof.
As a 303 pilot, I'm of course partial to the trailing edge brake/flap
combination. The manual says they can be deployed up to VNE (and
pragmatically, why not even faster--what the heck you're already a test
pilot....). I've opened them and pointed the ship nearly vertical and
didn't quite reach manuevering speed. Never popped them open at at anything
above pattern speed--the manual warns of a 2g deceleration if abruptly
deployed @ VNE.
Brent
limits.
not an engineer.
John Galloway
Old March 30th 04, 12:07 AM
Andreas Maurer
On 28 Mar 2004 22:53:07 GMT, John Galloway
limits.
Well, I have to admit that as fine as your solution sounds - it will
only be the cure for an extremely small part of all glider accidents.
How big is the fraction of overspeed/overG accidents after a spin
recovery that went wrong? 0.1 percent? 0.2 percent?
Certainly not higher - the only inflight breakups in such a situation
I ever heard of were the ASW-22 prototype (1981), the eta and the US
Nimbus, the first two being test flights of prototypes.
In the 22 case it was clear that the airframe would break up before
the flight beacuse it was not designed for the load factors that were
created by extreme asymmetrical water ballast load.
Bert Willing also exceeded the design limits of a 26 meter glider, but
his glider survived the incident without damage.
Investing a very small part of the costs for such a device in, say,
three spin-training flights per year, is probably going to make things
a lot safer.
I think the money is far better invested in a rescue system, be it
NOAH, bei it Soteira (which I prefer), or be it a BRS. A rescue system
will be able to safe the pilot in a lot more cases than a strong
airbrake.
Bye
Andreas
Old March 30th 04, 12:50 AM
W.J. \(Bill\) Dean \(U.K.\).
There was also the U.K. based Nimbus 4 in Spain.
The ASW20CL on 11th January 1987 was an overspeed accident. It did not
break up, control was lost and it hit the ground at very high speed.
I should have thought there was a case for an optional tail chute on
machines such as the big Nimbus and perhaps the Duo Discus, it was fitted to
the Janus and the Nimbus 2.
The ASW17 was available with a belly chute.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"Andreas Maurer" wrote in message
limits.
the flight because it was not designed for the load factors that were
a lot safer.
NOAH, bee it Soteira (which I prefer), or be it a BRS. A rescue system
airbrake.
Bye
Andreas
Old March 30th 04, 04:15 AM
Andreas Maurer
On Mon, 29 Mar 2004 23:50:20 +0100, "W.J. \(Bill\) Dean \(U.K.\)."
This makes it 4 accidents in the last 23 years.
Interesting case - is there a detailed rport available online?
I agree 100% - a tail chute (or better a belly chute) might be a good
idea.
I would not regard it as a primary Vne-avoidance device, but rather a
useful help to keep the speed down after an inflight breakup (e-g.
after a collision with loss of wing or tail), giving the pilot more
time to get out and maybe even stabilizing the falling wreckage.
Bye
Andreas
Old March 30th 04, 11:15 AM
I am afraid not.
I do not know whether this accident was investigated direct by the AAIB or
whether it was delegated to the BGA, but in either case U.K. accidents as
far back as that are not on-line.
snip
snip
Bye
Andreas
Old March 31st 04, 12:03 AM
Edward Downham
Subject: Devices for avoiding VNE?
Date: 30/03/2004 10:15 GMT Standard Time
Message-id:
I am afraid not.
snip
snip
Bye
Andreas
I don't know if this accident was the subject of a _formal_ AAIB investigation;
I do know that one of their guys spent some time with the wreckage and talking
to Schleicher, amongst others.
From what I remember (I was at the airfield the day this happened but didn't
witness the crash) the glider was observed to be hillsoaring and climbing in
weak thermals near the site. Eyewitness say it departed from level flight (in
what way I'm not sure) then went into a steepening dive from which it did not
recover. The height it started the dive from was estimated at 1200-1600', which
ties in with the speed it hit the ground.
I don't remember if there was ever a 'probable cause' given but several factors
were quoted post-investigation:
a) The pilot was new to type and fairly inexperienced (in gliders).
b) She was of quite light build.
c) She was an experienced hang-glider pilot.
d) The glider was being flown in comps. by another syndicate member and had
been ballasted in the tail to take it close to the aft CG limit (when flown by
her partner).
There is/was plenty of fuel for the speculative fire but I don't think we'll
ever know exactly why this happened...
P.S. I think it was actually a ASW-20_B_L, not that it makes an incredible
difference.
Aircraft Deceleration Devices SteveM8597 Military Aviation 10 April 13th 04 11:01 AM
GPS and Night Vision Devices Steve Products 0 February 12th 04 12:34 PM
WinPilot-compatible GPS devices Ted Wagner Soaring 21 January 12th 04 11:27 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
Airdropped Fusion Devices Blinky the Shark Military Aviation 4 September 17th 03 06:34 PM
