Republic XF-12 Rainbow
Old August 29th 17, 03:47 PM posted to alt.binaries.pictures.aviation
Miloch
Default Republic XF-12 Rainbow
https://en.wikipedia.org/wiki/Republic_XF-12_Rainbow
The Republic XF-12 Rainbow was an American four-engine, all-metal prototype
reconnaissance aircraft designed by the Republic Aviation Company in the late
1940s. Like most large aircraft of the era, it used radial engines—in this case,
the Pratt & Whitney R-4360 Wasp Major. The aircraft was designed with maximum
aerodynamic efficiency in mind. The XF-12 was referred to as an aircraft that
was "flying on all fours" meaning: four engines, 400 mph cruise, 4,000 mile
range, at 40,000 feet. It is still the fastest piston-engined airplane of this
size, exceeding by some 50 mph the Boeing XB-39 of 1944. Although highly
innovative, the postwar XF-12 Rainbow had to compete against more modern jet
engine technology, and did not enter production.
In August 1943, U.S. President Franklin D. Roosevelt's son, Colonel Elliot
Roosevelt, commander of the F-5 (modified P-38) "recon" unit, recommended the
acquisition of a dedicated high-performance photo reconnaissance aircraft,
capable of providing pre-strike target acquisition and photo interpretation.
Followed by additional overflights to provide post-strike analysis of their
subsequent destruction, this would give commanders the ability to make pivotal
strategic decisions and set up subsequent raids. The XF-12 was Republic
Aviation's attempt to meet those goals. Its primary competition during this time
was the Hughes XF-11. Both were introduced at the same time, and both were
powered by the new P&W R-4360. The XF-12's first flight was made on 4 February
1946. During the XF-12's subsequent flight testing and development period, it
demonstrated the capability of operating at 45,000 feet (14,000 m), at a speed
of 470 mph (760 km/h), over a range of 4,500 mi (7,200 km), so it met and
exceeded the design goals for which it had been designed. Neither the XF-11 or
the XF-12 was purchased in any quantity by the U.S. Army Air Forces (two each),
as their need evaporated after hostilities ended in World War II.
Role
Strategic aerial reconnaissance
National origin
United States
Manufacturer
Republic Aviation
First flight
4 February 1946
Retired
June 1952
Status
Cancelled
Primary user
United States Army Air Forces
Number built
2
Unit cost
$1.25 Million (1946 Dollars)
The first prototype was damaged in landing on 10 July 1947. The aircraft was
undergoing maximum landing weight tests. During one particularly hard landing,
the right main gear was severed at the engine nacelle. The aircraft bounced
hard, and staggered back into the air. The test pilot was able to maintain
control, and climb to a safe altitude. He continued to fly the aircraft to burn
off excess fuel, to both make the aircraft lighter and lessen the chance of
fire. Once excess fuel was burned off, the pilot landed on the left main gear
and the nose wheel. The pilot touched down, and while keeping the right wing up,
scrubbed off as much speed as possible before it touched down. During the
incident the aircraft suffered significant damage. The right wing spar was
cracked, and the #3 and #4 engines and props needed to be replaced due to the
ground contact. The aircraft was repaired by Republic, and later returned to
service.
On 7 November 1948, prototype number two, 44-91003, crashed at 13:00 while
returning to Eglin Air Force Base, Florida. The number 2 (port inner) engine
exploded as the aircraft was returning from a photographic suitability test
flight. The pilot was unable to maintain control due to violent buffeting, and
he ordered the crew to bail out. Five of the seven crew escaped safely,
including pilot Lynn Hendrix, rescued by Eglin crash boats and helicopters. The
airframe impacted two miles south of the base in the Choctawhatchee Bay. Sgt.
Vernon B. Palmer and M/Sgt. Victor C. Riberdy were killed. The first prototype,
which returned to service in 1948, continued the flight testing and development
phase. After the U.S. Air Force declined to order any additional aircraft, and
with the loss of the second prototype, the flight testing period wound down. In
June 1952, the first prototype, 44-91002, was retired (having flown just 117
additional hours from 1949-1952), was stricken from the U.S. Air Force
inventory, and ended up as a target on the Aberdeen Proving Ground, Maryland.
Had the XF-12 Rainbow been available in 1944, it almost inevitably would have
been ordered in quantity, and along with its civilian counterpart, the whole
postwar structure of aircraft markets might have been altered. As it was, the
XF-12 disappeared into oblivion, despite its graceful lines and high
performance. According to Machat, the Rainbow remains the ultimate expression of
multi-engine, piston-powered aircraft design. Its high speed, near-perfect
streamlined form, and neatly cowled engines make it a design classic, often
unappreciated, and not very well known. The XF-12 was the fastest, four engine
pure piston-powered aircraft of its day, and the only one ever to exceed 450 mph
in level flight. The closest the USAF ever got to the Rainbow, the 44 (converted
from bombers) Boeing RB-50Bs, could only reach 385 mph at 25,000 feet with
exactly the same engines (Wasp Majors).
Specifications (XF-12)
General characteristics
Length: 93 ft 9 in (RC-2 version 98 ft 9 in) (28.56 m)
Wingspan: 129 ft 2 in (RC-2 version 129 ft 2 in) (39.37 m)
Height: 28 ft 1 in (RC-2 version 29 ft 11 in) (8.55 m)
Wing area: 1,640 ft² (RC-2 version 1,640 ft²) (152.36 m²)
Empty weight: 65,000 lb (RC-2 version 67,000 lb) (29,483 kg)
Loaded weight: 101,400 lb (RC-2 version 114,200 lb) (45,994 kg)
Max. takeoff weight: 101,400 lb (RC-2 version 114,200 lb) (45,994 kg)
Powerplant: 4 × Pratt & Whitney R-4360-31 Radial engine, 3,250 hp (2,423 kW
each) each
Performance
Maximum speed: 470+ mph (RC-2 version 450 mph) (756 km/h)
Range: 4,500 miles (RC-2 version 4,100 miles) (7,242 km)
Service ceiling: 45,000 ft (RC-2 version 40,000 ft) (13,716 m)
Rate of climb: 5,000+ ft/min (RC-2 version 5,000+ ft/min) (1,524 m/min)
Wing loading: 61.83lb/ft² (301.9 kg/m²)
Power/mass: hp/lb (kW/kg)
Old August 30th 17, 08:15 PM posted to alt.binaries.pictures.aviation
J Three
I've never know you to be wrong but this doesn't look like a fighter.
Isn't the XF indicative of a fighter under testing while bombers get
XB?
Old August 30th 17, 10:27 PM posted to alt.binaries.pictures.aviation
Miloch
In article , J Three says...
XB?
Dunno...never heard of it until I started to research it for the mornings post.
Designed to be for recon and nothing else.
If it's good enough for Wiki, it's good enough for me.
Old August 31st 17, 06:12 AM posted to alt.binaries.pictures.aviation
Bob (not my real pseudonym)[_2_]
On Wed, 30 Aug 2017 14:15:24 -0400, J Three
XB?
During WWII, the USAAF used 'F' to denote reconnaissance (F for Foto,
since P was already used for Phighter [okay, Pursuit]), i.e. Lockheed
F-4, F-5 variants of the P-38; F-6 variant of the P-51; and even the
F-13 variant of the B-29.
After the war, 'R' was used for a bit as the primary designator, but
quickly became a prefix to the primary aircraft mission, such as
RB-26, RB-36, etc.
More at:
https://en.wikipedia.org/wiki/List_o...nce_air craft
Rainbow CF-5 Canuck[_10_] Aviation Photos 2 June 21st 10 12:41 PM
Rainbow B-737 Canuck[_10_] Aviation Photos 0 June 20th 10 06:25 PM
Rainbow CF-5 Canuck[_10_] Aviation Photos 0 June 20th 10 06:25 PM
In (or over) the rainbow [email protected] Instrument Flight Rules 5 May 5th 08 11:30 PM
In or over the Rainbow [email protected] Piloting 7 March 23rd 08 02:06 AM
