SeeYou - "Calculate minimum distance to next observation zone"
Old May 17th 04, 09:33 PM
Tom
Default SeeYou - "Calculate minimum distance to next observation zone"
SeeYou has an option in the task window called "Calculate
minimum distance to next observation zone" Does anyone know
what calculation this uses? Say I fly 20 miles west to turn
1 on an AAT task with 5 mile areas. Turn 2 is 6 miles
north of the midpoint of the first leg, but I fly straight
back home east on the first leg, bypassing turn 2 to the
south. I would expect the closest I got to the second turn
area was at the midpoint of the first leg on the way back
home , so my distance is 30 miles? SeeYou seems to be doing
something other than this. As I make the 2nd turn area
larger, the distance SeeYou calculates gets longer. Can
anyone explain?
Old May 18th 04, 08:07 AM
Marcel Duenner
Tom wrote in message . ..
anyone explain?
The achieved distance is from Start via Turn1 to Best Marking Point.
The Best Marking Point is the point from which you have the shortest
distance to fullfill the task. So Best Marking Point is not half way
home because you will find that the minimum distance from your track
via Area2 starts somewhat past halfway home. Rough guess it must be a
bit less than 9 miles from home assuming a 4 mile radius for Area2.
Regards
Marcel
Why walk when you can soar?
State Record Question - Minimum Increase for Distance Records Gary Emerson Soaring 3 November 11th 03 05:18 PM
15 M Time Management Nationals Kilo Charlie Soaring 12 August 15th 03 04:09 AM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 05:12 PM
new TASKs and SCORING - or roll the dice CH Soaring 0 August 10th 03 08:32 AM
