Region 4 S: ELT Mandatory
Old June 17th 04, 01:59 PM
Chris OCallaghan
Default Region 4 S: ELT Mandatory
I just received a note from Lanier Frantz stating that all competitors
at R4S must have an ELT. I understand the reason for this decision,
but I question whether it will have the intended effect. I have long
been against mandatory ELT use in soaring comopetitions for one reason
only: they do not operate as advertised. While 121.5 MHz ELTs are
useful in locating a crash scene, they are nearly useless as a life
saving device. And, in fact, these units only activate properly in
about 12% of crashes.
The management of R4S
Old June 18th 04, 11:43 PM
Mike Lindsay
In article , Chris
OCallaghan writes
And one of the snags of this device is that they have been know to go
off accidentally.
When that happens a great bit expensive helicopter suddenly appears over
your trailer....
Mike Lindsay
Old June 19th 04, 07:47 PM
Eric Greenwell
off accidentally.
your trailer....
The one I have can be disabled with a pin (with an attached red flag to
make it obvious). I use to disable it for trailering, then I got lazy,
and 50,000 trailer miles later, no activation. My trailer is metal, so
the signal wouldn't get out anyhow.
Has anyone had an ELT activate while trailering?
Eric Greenwell
Washington State
USA
Old June 20th 04, 12:40 AM
Tom Serkowski
Eric Greenwell wrote in message ...
I turn mine off after each flight.
Just before turning off the master switch, radio goes to 121.5, then I
toggle ELT power from standby to off pausing for one blip in the on
position. This way I can also check for any ELT's that may be active
at the airport.
When I turn on the master, the radio's on 121.5 and I don't switch
until the ELT is on and verified functional with one blip.
I keep meaning to have someone shove me in the trailer while in the
cockpit to see if the metal trailer blocks the signal, but still
haven't remembered to do it.
-Tom
ASH-26E
REGION 6 SOUTH CANCELLED Region 6 Contest Manager Soaring 0 June 9th 04 03:29 AM
Perry, Region 5 - April 19-24 Cruise the grid in style John Seaborn Soaring 0 April 2nd 04 08:54 PM
Will there be a Region 10 Contest this year??? Gary Emerson Soaring 2 January 20th 04 10:38 PM
2004 Region 3 Contest - Dansville, New York Region 3 Contest Soaring 0 January 5th 04 02:07 PM
Info and Links for WX in the Russian Far East Region Frode Berg Piloting 4 July 22nd 03 10:52 PM
