Becker 4201 multiple failures
Old August 9th 04, 09:43 AM
Jean
Default Becker 4201 multiple failures
I had a similqar problem after the battery leaked ... After numerous fixes
it was still not working. I finally solved the problem by replacing the mike
Jean
"Bruce" a écrit dans le message de
om...
Can anyone recommend a repair facilities for a Becker AR4201
transceiver other than Becker Avionics in Mirimar FL? I don't trust
the places listed on the Becker Web Site because I tried Spirit
Avionics in Ohio, and they we're even allowed to open the unit.
I have a three year old Becker 4201 that failed Dec'03, and again July
'04. The Dec'03 repair took three (3) months, and they only
re-flashed the software (cost=$280). Same failure and I'm getting the
same run-around, no response to emails, or voice mails. When I reach
them, Sebastian says to call "next tuesday" every week. The radio
trasmits and receives carrier wave only, no voice. ie, just a 'click'
heard both ways. The glider wiring is supperb, so I'm lost as to the
cause of the multi failures.
Help is greatly appreciated,
Bruce
FS 2004 with multiple monitors - how to save settings? Horst Walter Simulators 5 December 8th 04 02:29 PM
How common are multiple point failures? Michael Owning 9 April 30th 04 09:38 PM
Where is approach good about multiple approaches and clearances in the air? Andrew Gideon Instrument Flight Rules 29 February 14th 04 03:51 AM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 07:32 PM
Microair vs Becker Ian McPhee Soaring 0 August 30th 03 10:45 PM
