Magnus Effect
Old October 20th 04, 05:16 AM
COLIN LAMB
Default Magnus Effect
If a wing is replaced by a rotating cylinder, with the forward surface
rotating upward, lift will be produced. The local air velocity is high on
top and low on the bottom. This upward force is known as magnus effect.
The information above comes from my helicopter handbook. The theory is used
to explain some helicopter principles, but caused me to wonder more about
it. Has anyone every produced an airplane using the magnus effect? If the
cylinder is rotating faster, I would expect that lift would be increased.
Does anyone know if there have been any writings and/or test aircraft? Not
much use with a glider, for obvious reasons - but the answer would make me a
bit smarter. I was not able to find much on the internet.
Thanks, Colin N12HS
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.775 / Virus Database: 522 - Release Date: 10/8/04
The Meredith Effect Corky Scott Home Built 19 September 4th 04 05:01 PM
Weather and ground effect Kevin Chandler Piloting 12 April 23rd 04 06:01 AM
Date of effect now 1 October 2004 for revised IGC-approvals for certain legacy types of GNSS flight recorder Ian Strachan Soaring 0 March 15th 04 03:32 PM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 06:11 AM
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder Ian Strachan Soaring 56 December 2nd 03 09:08 AM
