Metal in the Oil Cooler
Old August 17th 04, 06:57 PM
Justin H
Default Metal in the Oil Cooler
My Lycoming o-290 swallowed an exhaust valve and i suspect metal in the oil
cooler. where is a place that does experimental work that could check it.
thanks in advance for anybodys help
Justin
Lexington, KY
Old August 18th 04, 04:35 AM
Kyle Boatright
"Justin H" wrote in message
oil
Justin
Lexington, KY
You can flush the cooler yourself and (if you're interested), collect any
metal flakes. You could do it in your kitchen sink, with a white towel over
the drain to catch any debris. Flush it several times in each direction and
see what comes out other than a bit of oil. After that, clean the sink
really well and throw away the towel, or you'll be subject to the wrath of
She Who Must Be Obeyed...
Old August 18th 04, 05:16 AM
Morgans
over
and
Flush it with what, water? Best to use a solvent to free up those buggers.
I know they sell a can that is used to flush transmission coolers; I had to
use one at OSH, when my transmission in my equipment van packed it in. If
not something like that, gas or kerosene, but at any rate, not water, and
not in a kitchen sink.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.737 / Virus Database: 491 - Release Date: 8/11/2004
Old August 18th 04, 06:39 AM
Craig
"Justin H" wrote in message ...
Damage like that and ANY indication of the possiblity of having metal
in the engine and I would do a complete teardown and inspection. A
teardown and inspection now is a heck of a lot cheaper than having a
catastrophic failure sometime in the future. There is nowhere that I
have to be or have my family at, that would cause me to put them
onboard the aircraft without having done a complete inspection after
an incident that might have put abnormal amounts of metal in the oil
system.
YMMV...but when it comes to my family, I am much more cautious than
normal.
Craig C.
Old August 18th 04, 12:28 PM
Kyle Boatright
"Morgans" wrote in message
any
over
and
of
buggers.
to
Dag-nabbit, you're right. Not sure what I was thinking.
KB
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 11:18 PM
Deburring sheet metal and filing edges? DL152279546231 Home Built 1 April 25th 04 01:47 AM
Oil cooler? Rick Home Built 1 March 22nd 04 10:41 AM
Oil Cooler for Auto-Conversions Bruce A. Frank Home Built 0 October 30th 03 07:06 AM
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 08:08 PM
