US source for wheel on the tongue of Cobra trailer?
Old January 17th 05, 11:36 PM
Mark Zivley
Default US source for wheel on the tongue of Cobra trailer?
The wheel on our Cobra trailer is no longer in "as new" condition. It's
about 8.5" diameter and has about a 3/4" shaft. Has anyone sourced a
replacement in the U.S. that they can recommend?
Mark
Old January 18th 05, 12:58 AM
I got one from Knauff and Grove. I think they still sell Cobra parts.
M&H is another source. Both have given me prompt attention and quick
turnaround.
On the west coast, Rex and Noelle Mayes at Williams Soaring Center
have provided good service.
Old January 18th 05, 01:28 AM
KP
Hi Mark
When the dolly wheel on my Cobra had to be replaced I went to a wheel
and caster shop in San Franicago and got one that fit, same bore size
and outside diameter. Hello Yellow Pages
KEN (KP)
It's
a
Mark
Old January 18th 05, 04:51 AM
Check your local hardware store.
Main criteria are outside diameter and width (so it will fit) and
load-bearing capacity, though it's highly likely that anything that
sort of looks like the original wheel will be fine. The newer trailers
have these really neat looking pneumatic tires but mine (1992) was just
solid rubber.
I used a hardware store bolt as the new axle. I think it was slightly
smaller than the original. If it had been larger, I would have drilled
out the mounting arms.
We're not talking about high-strength, heat-treated steel machined to a
few thousands running in high-speed tapered roller bearings, or the
ability to run true with no vibration at 75 mph. Max speed is in feet
per minute unless the wheel drops to the road while the trailer is
under tow...in which case you have a different kind of problem. And
will need a new wheel, anyway.
Chip Bearden
ASW 24 (& Cobra trailer) "JB"
It's
sourced
a
Mark
Cobra Trailer Hookup [email protected] Soaring 12 January 12th 05 04:08 PM
Cobra Tongue Strut Removed Finally Brian Iten Soaring 0 December 4th 04 08:54 PM
COBRA Skin Trailer Protector - Commercial John Seaborn Soaring 0 July 20th 04 05:38 PM
Cobra Trailer Axel Replacement Carter Soaring 7 July 7th 04 03:06 PM
Cobra Trailer Question Deputy Dog Soaring 7 January 3rd 04 04:11 PM
