Successful Winch Launch Operations from Public Use Municipal/County Airports
Old July 12th 19, 10:01 PM posted to rec.aviation.soaring
Default Successful Winch Launch Operations from Public Use Municipal/County Airports
Good day,
I'm looking for successful Commercial/Club Operators winch launching gliders from small Public Use Municipal/County Airports. I want to understand how you're successfully working with GA Power pilots and Public Servants to run your winch-glider operation.
Please let's keep the "power and gliders don't mix" and "winch and GA traffic don't mix" comments to low rumble so those folks who are successfully working with our GA and Public Servants partners can speak up.
Respectfully,
Richard Starke
five seven one 379 0139
Old July 12th 19, 10:34 PM posted to rec.aviation.soaring
Tony[_5_]
Best example I'm aware of is Don Ingraham at Cross Country Soaring in Fairbault Mn
Old July 12th 19, 10:53 PM posted to rec.aviation.soaring
AS
Default Successful Winch Launch Operations from Public UseMunicipal/County Airports
On Friday, July 12, 2019 at 4:01:55 PM UTC-4, wrote:
Good day,
Respectfully,
Richard Starke
There is a successful commercial 'winch only' operation on Dillingham Field, HI.
The Carolina Soaring Association operates their winch off of a busy county airport with mixed traffic ranging from biz-jets to ultralights to gyro-planes. Communication is key!
Uli
'AS'
Old July 13th 19, 05:58 AM posted to rec.aviation.soaring
Piet Barber
Brian Collins at Eastern Soaring Center (right next door to you) has a commercial winch operation at Petersburg, WV. I've taken several winch tows out of that airport in my Duo Discus and really enjoy flying there.
Old July 13th 19, 05:16 PM posted to rec.aviation.soaring
Mike Hendron
We have had success with winch operations at the Nephi airport in Utah over the past few years. It is a large airport with some power traffic, but not a lot. Some transient training flights, local skydiving operations, autogyro operations, plus our aerotows. But we have always been able to coordinate by radio and vigilant observation without any conflicts. We work closely with the airport manager, and typically do a NOTAM on days we winch as a courtesy as well. And we try to maintain good working relationships with all the major parties at the airport. Winching is secondary at this point, so it isn't a frequent, but when we do winch we tend to make it an all day activity.
Mike Hendron
Utah Soaring Association
Old July 14th 19, 02:41 AM posted to rec.aviation.soaring
Thanks for all the great feedback on this forum and phone calls I received.
Old July 16th 19, 05:51 AM posted to rec.aviation.soaring
2G
Nobody mentioned how they keep cables and power planes separated.
Old July 16th 19, 06:59 AM posted to rec.aviation.soaring
Hi Richard, I own/operate a commercial glider operation (16 years now!) at a Municipal airport in Faribault,MN called Cross Country Soaring, Inc. The majority of our operations are behind a Socata Rallye 235E pulling a pair of Grob 103 Twin IIs and a dozen private owners. We do a fair amount of winching also. A decade ago I bought a 330HP Gehrlein winch and have a mile of 6MM Dyneema on the drum. The trick to operating at a GA airport (in my experience) is to get everyone on board - the local power pilots, the airport manager, FSDO. You can't approach it with, "gliders are one of the seven categories of aircraft and have a right to operate from federally-funded airports blah blah". That argument can be easily toppled at a meeting (that you aren't invited to) where concerns about safety, legit or otherwise, win the day. Instead, write up a "Winch Operations Manual" which covers every step of a winch launch. It should absolutely reek with courtesy towards power traffic, professionalism, and clear radio communication. Once your local FSDO signs off (yup - send them a copy), the airport manager can relax and most local power pilots think it looks cool as hell. :-) The hard part is playing second fiddle while winching. E.G. radio: "Glider holding for inbound traffic (ten miles out)". Or, "Winch retrieve car, clearing the active for Warrior on downwind (doing it's 10th touch-and-go)". That's hard. But, it's the price. Also, take the local power guys up on a launch or two. No charge.. It will be the best money you ever spent. The main goal is to appear professional and courteous to the more...er...rigid pilots out there. Good luck!
Old July 16th 19, 10:19 AM posted to rec.aviation.soaring
John Foster
On Monday, July 15, 2019 at 10:59:23 PM UTC-6, wrote:
Hi Richard, I own/operate a commercial glider operation (16 years now!) at a Municipal airport in Faribault,MN called Cross Country Soaring, Inc. The majority of our operations are behind a Socata Rallye 235E pulling a pair of Grob 103 Twin IIs and a dozen private owners. We do a fair amount of winching also. A decade ago I bought a 330HP Gehrlein winch and have a mile of 6MM Dyneema on the drum. The trick to operating at a GA airport (in my experience) is to get everyone on board - the local power pilots, the airport manager, FSDO. You can't approach it with, "gliders are one of the seven categories of aircraft and have a right to operate from federally-funded airports blah blah". That argument can be easily toppled at a meeting (that you aren't invited to) where concerns about safety, legit or otherwise, win the day. Instead, write up a "Winch Operations Manual" which covers every step of a winch launch. It should absolutely reek with courtesy towards power traffic, professionalism, and clear radio communication. Once your local FSDO signs off (yup - send them a copy), the airport manager can relax and most local power pilots think it looks cool as hell. :-) The hard part is playing second fiddle while winching. E.G. radio: "Glider holding for inbound traffic (ten miles out)". Or, "Winch retrieve car, clearing the active for Warrior on downwind (doing it's 10th touch-and-go)". That's hard. But, it's the price. Also, take the local power guys up on a launch or two. No charge. It will be the best money you ever spent. The main goal is to appear professional and courteous to the more...er...rigid pilots out there. Good luck!
How do you deal with waiting for inbound traffic with a rope laying the length of the runway? Or do you not lay it out until all is clear? I'm contemplating something similar at my home airport, but it is used by Air Tractors that fight wildfires during the summer months. They tend to think they own the whole show and have priority over everything else.
Old July 16th 19, 01:50 PM posted to rec.aviation.soaring
AS
You summed it up nicely, Don! in addition to all the things you mentioned, we ask the city employees running the airport to add 'Gliders operating off the field' to the AWOS. Also, the winch operator announces every takeoff warning approaching traffic not to do a mid-field crossing below a certain altitude (typically twice the expected release altitude) for the next minute since wings and Spectra don't mix well. We also invite the local power and jet guys regularly to fly with us. The biz-jet guys have followed our request to call in an estimated time overhead instead of '15 miles out to the north', which gives us a much better idea for whether to go or hold the launch. As I mentioned above, communication is key!
We are fortunate enough to be able to operate off the grassy area next to the main runway, so we don't have that problem.
Uli
'AS'
Identifying Uses of Municipal Airports W[_3_] Piloting 0 May 10th 15 01:05 AM
Successful Winch Trials in Bogota, Colombia Markus Graeber Soaring 1 February 6th 08 05:09 AM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 01:33 AM
Hangars at Public Airports (US) Jim Kellett Soaring 10 April 7th 04 07:13 PM
Glider Operations at U.S. Public Airports with Intersecting Active Runways Romeo Delta Soaring 9 February 4th 04 08:41 PM
