Wheel Brake on G102
Old March 1st 05, 09:04 PM
Ken Pruchnick
Default Wheel Brake on G102
Hi All
Our drum wheel brake on the club Grob 102 is almost useless. I was
wondering if there is a conversion to a diskbrake.
Ken (KP)
Old March 1st 05, 09:25 PM
Ken Pruchnick wrote:
Hi All
Ken (KP)
Wings and Wheels has a TOST conversion that mentions Astir CS.
I considered it once for mine but it's listed at $1395 us, and
that's too steep. I did replace the pads and I heard about
some motorcycle shop that could really soup up the drum brake
somehow. You might research that.
In the meantime, don't point the glider at anything you can't
afford to pay for.
Toad
Who is waiting for his G102 to get it's shiny new counterweights
installed, so he can go real fast this spring/summer.
Old March 1st 05, 09:58 PM
Robin Birch
In message , Ken
Pruchnick writes
Hi All
Ken (KP)
How bad is bad? Mine won't tip it on the nose if I apply it but it does
slow reasonably well.
Robin
Robin Birch
Old March 1st 05, 10:32 PM
Stefan
Tost drum brakes have the problem that they are too small, therefore
overheat which hardens the plates (or however this is called in
English). Try to use them only in an emergency. Take them apart after
each serious use, but at least yearly, and sand the plates.
the construction not very convincing and too expensive.
Stefan
Old March 2nd 05, 08:01 AM
Hey Kilo Papa,
Have you considered sending the brake to Vintage Brake in Sonora, CA
(http://www.vintagebrake.com/index.html)? They are familiar with the
TOST brake and charge about $175-$250 to improve the brake's
performance. A search on RAS has will indicate that they reportedly do
good work. I had a TOST brake re-worked by them but haven't actually
tried it because I'm STILL waiting for the repair on A5.
Hi All
Ken (KP)
SZD-55 Wheel Brake Adjustment WDM Soaring 2 January 20th 11 10:25 AM
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 07:15 PM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 06:22 AM
Cobratrailer&brakes Greg Arnold Soaring 5 October 6th 03 04:14 PM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 11:29 AM
