Vibration Monitor (Hyde, Wanttaja?)
Old March 6th 05, 06:47 PM
RST Engineering
Default Vibration Monitor (Hyde, Wanttaja?)
Necessity, as they say, is a mother.
I am in the process of reinventing a square wheel called a vibration
monitor. The electronics is relatively trivial IF the input and output
parameters are known.
What we know is that the engine is going to have a fundamental frequency at
cruise RPM. Let's take the math-simple engine RPM of 2400. This gives us a
fundamental frequency of 2400/60 or 40 Hz.
But wait, he said. There are going to be other (sub) harmonics of that
frequency that will be of some interest. And, those harmonics will change
as a function of the engine being a two or four stroke, four or six
cylinder.
So, oh wise and noble gurus of engine stuffings, what (sub) harmonics are
going to be of most interest to us and what is their mathematical
relationship to the fundamental?
As an extra bonus question, my sensor is going to be an old phonograph
cartridge. Should I use the lightest weight "needle" that I can find? How
about a tiny little ball of lead at the tip of that needle? Would that help
the sensor? Or hinder it?
Lastly, once I get this sucker up and running with you all's good ideas, is
anybody game to bolt it onto their flying machine and report results? I can
do it for the 182, but I'd really like some other real-world reports.
Old March 6th 05, 07:17 PM
On Sun, 6 Mar 2005 09:47:58 -0800, "RST Engineering"
Can't help you on the first issue, but adding the ball of lead to your needle is
going to lower its OWN harmonic frequency. The harmonic of the needle may be
brought within the normal range of the engine. Which means you'll get a false
reading based on the characteristics of the sensor.
I know it's contrary to the Weir philosophy, but commercial accelerometers are
available for less than $100. Just because it's not in the Digi-Key catalog
doesn't mean it doesn't exist. :-)
http://www.vernier.com/probes/probes...plate=acc.html
Since this is for an article, you might be able to sweet-talk Analog Devices out
of some of their acceleration transducers...they're pretty cheap, though the
company normally doesn't sell in lots of less than a thousand.
http://www.analog.com/en/subCat/0,28...0%255F,00.html
I got a buddy who works for a company that handles this stuff...let me email you
his address.
Happy to stick it on my Fly Baby. A neat spot would be down on the axle next to
the video camera....
Old March 6th 05, 07:23 PM
Two "whoops":
his address.
Whoops #1: I had his company name slightly wrong. They don't handle
accelerometers.
Whoops #2: I forgot this was an *engine* vibration monitor. Haven't pulled the
G-level yet to put the engine down on the axle. Still willing to install the
sensor, though.
I posted my earlier adventures with a recording accelerometer about ten years
ago. Here's the article:
http://www.wanttaja.com/avlinks/accel.htm
Old March 6th 05, 08:33 PM
Dan, U.S. Air Force, retired
his address.
I see accelerometers like these on e-bay all the time.
Old March 6th 05, 08:48 PM
Ron Wanttaja wrote:
snip
On F-4s we had statistical accelerometers which had a 4 window display.
Each window showed how many times a certain G had been reached. The
display was electromechanical. It would be interesting to build a small
digital equivilent to install in HB aircraft. It shouldn't be too
difficult.
Old March 6th 05, 11:37 PM
Robert Bonomi
cylinder.
*most* of the stuff 'of interest' is going to occur at the frequency of
ignition in the #1 cylinder.
You'll have "similar things" happening at the appropriate phase delay for
each cylinder.
*IF* everything is behaving exactly the same, that _should_ give you a
composite signal at (no. of cylinders) * (cyl #1 ignition frequency).
One also has to consider any drive-shaft powered 'accessories', that
may be operating at a _different_ speed than the main engine. (gear ratio,
and/or belt drive with different pulley sizes)
One form of 'bad news' is something that is going on in one cylinder that
is _different_ than what is happening in the rest of 'em. This may be
merely 'different amplitude', or it may be 'different wave-form.
Another form is something "recurring" at a frequency _other_ than what
can be explained. e.g., a flat spot on a roller in a roller bearing,
will have a characteristic frequency based on how many times the roller
rotates, per shaft rotation. Which is likely to be some "weird" ratio.
Oh Lordie!
To get an _accurate_ measure of vibration, the 'system under test', and the
'testing system' must be *isolated* (mechanically, "vibrationally") from each
other. Then you detect the vibration in the system under test, by measuring
the instantaneous differences in position, relative to the testing system.
When the 'testing system' is mounted _on_ the 'system under test', there
is a complication of 'signal' being transferred *through* the mounting, which
is then *not* detected by the pick-up, because _both_ components are affected.
You can 'approximate' isolation with some sort of a 'suspension' system --
e.g. springs. This, however, ends up "complicating" things, because what
it does is just introduce a 'delay' in the transfer through the suspension
mechanism, *and* a probable, delayed, induced "negative" component restoring
'equilibrium'. Theoretical analysis can get *really* hairy real quick.
To accurately track vibration, you have to have a sensor that will _move_
as far as the maximum 'excursion' of the system under test. It has to
have enough structural strength that the sensor, itself doesn't "flex",
yet inertia has to be low, to enable it to 'mimic' every motion of the
system under test.
You've got two *entirely* different kinds of 'sensor' possible:
1) something 'firmly attached' to the airframe, with a "Cats whisker"
in contact with the engine, this measures engine movement relative
to the airframe.
2) something 'firmly attached' to the engine, using a cat's whisker against
a 'suspended' (as supported by a suspension) mass to compare against.
This measures the 'movement' of the sprung mass, relative to the engine.
Which is "more or less" equivalent (though opposite in sign, naturally
to the movement of the engine relative to the "surround".
In either case, the "cat's whisker" should be as light and rigid as possible
In the latter case, "bigger is better" for the 'reference mass', subject to
the suspension mechanism, and resonances, etc. in *it*.
Old March 7th 05, 03:07 AM
jc
snip
How
help
A lot depends on the range of frequencies, any sensor will have its own
fundamental frequency- multiple sensors may be a good idea. Geophones seem
to be good up to a few hundred Hz, cheap but difficult to get qty one. For
the application a speaker may be the clue (as a second sensor).
regards
jc
LEGAL - I don't believe what I wrote and neither should you. Sobriety and/or
sanity of the author is not guaranteed
EMAIL - and are not valid email
addresses. news2x at perentie is valid for a while.
Old March 7th 05, 08:11 AM
Frank van der Hulst
[snip]
cartridge.
And you *need* to use that phonograph needle?
Analog Devices sells cheap MEMS-based accelerometers (e.g. ADXL202). You
could even use two or 3 axes. The output a 5V square wave whose duty
cycle is proportional to acceleration.
Frank
Old March 7th 05, 08:09 PM
Joerg
Hello Jim,
Just a thought: Usually the time between the onset of a vibration and
some catastrophic failure is rather short. I believe what also needs to
be detected is the higher frequency stuff that can happen well before
this. Such as friction sounds from a bearing or cam not getting enough
lubrication.
Regards, Joerg
http://www.analogconsultants.com
Old March 8th 05, 01:59 AM
Ernest Christley
I should be able to volunteer a rotary by the end of the summer.
Since you won't know what frequencies should be there, could you make it
a sort of historical tracking system, with maybe some sort of alarm that
goes off if something starts going out of whack from historical data?
Wierd vibration -- Prop or engine, balance or not??? Chuck Owning 17 December 1st 04 03:12 PM
Pinging Ron Wanttaja - "Unporting?" Bob Chilcoat Home Built 13 November 24th 04 08:28 PM
Vibration Testing Jim Weir Home Built 20 October 10th 04 08:22 AM
Vibration Testing Jim Weir Owning 21 October 10th 04 08:22 AM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 06:32 PM
