Fueling from Plastic Containers and Blowing yourself up?
Old March 26th 05, 04:58 PM
Juaquin Murrieta
Default Fueling from Plastic Containers and Blowing yourself up?
I just read the thread above on static electricity problems associated
with using jerry cans of various compositions. I have a couple
questions and comments.
First of all, does anyone really know of an accident anywhere? I
mean, is there anyone out there in this ng who has ever seen a fire
start from a static discharge associated with one of these cans? I
have heard about this for years, but Wal-Mart and hundreds of other
retail outlets sell gas cans that are made of nonconductive plastic.
The red plastic ones I have are not conductive. And...it's obvious if
you have a conductive can, you can get rid of the electrons real easy
by pre-grounding. I'd bet that my red-plastic gas cans are completely
nonconductive however.
So, I'm thinking that even if you have a big electron buildup on the
plastic can, it can't flow fast enough to make a spark anyway.
I think the older metal cans were more dangerous because they did
conduct and if they were isolated and built up electrons, those
electrons could move fast through the metal spout and make a spark.
Even then, however, I have never heard of a real accident from filling
a tank anywhere. Yes, I've heard rumors of accidents, but does anyone
out there in RAH- land know of a specific accident happening that was
caused by using any fueling can, ever?
About a year ago, I saw a video clip on TV where this guy went to
fill a can in the back of his pick-em-up truck and some gas fumes sort
of exploded, burning him quite badly. But, this is the only accident
I've ever heard of or seen first hand and it was something a little
different since it was a spark from a gas pump nozzle somehow.
Also, it's a matter of the chemical kinetics. Since gasoline is so
volatile the hydrocarbon/oxygen ratio in the air above the liquid
gasoline in one of those cans is too high for combustion. You can
throw a cigarette in a can of gas like that and it will most likely go
out. The kinetics for burning are just not right because of the
overload of hydrocarbons. Of course at the mouth of a gas can things
are different. You can have perfect kinetics for burning since the
hydrocarbons are escaping into the atmosphere there is plenty of
oxygen.
I know that kerosene for instance is much more dangerous because it's
more oily and less volatile. So, you have perfect kinetics for
burning in the air above the liquid in a gas can. We don't put jet
fuel in gas cans for that reason.
Anyway, is there anyone out there who knows of a real accident using
either metal or plastic cans?
Just curious
----Whaa Keen
"The only difference between a nobleman and a commoner is that the
nobleman thinks one thing and says another."
--Zorro
Old March 26th 05, 05:02 PM
C J Campbell
"Juaquin Murrieta" wrote in message
Just curious
Well, it is one way to know for sure if you are going to heaven. :-)
Yes, I would like to know if there have been any accidents attributed to the
composition of the can, too.
Old March 26th 05, 05:58 PM
Jeff
It is very well documented that there is a hazard with metal gas cans being
filled while in the back of pickup beds with plastic bed liners. Here is a
link to an article that also documents the problem occurring with plastic
portable fuel containers. http://www.pei.org/FRD/gascan.htm
Chevron has a very detailed news release located at
http://bioengr.ag.utk.edu/extension/...re-gascan.html
Here are a few other links
http://www.cdc.gov/niosh/hid2.html
http://edis.ifas.ufl.edu/pdffiles/AE/AE17400.pdf
Do a search on google.com and you will get hundreds of sites.
Jeff
oxygen.
Just curious
----Whaa Keen
--Zorro
Old March 26th 05, 06:13 PM
John Ammeter
On Sat, 26 Mar 2005 15:58:42 GMT,
My bet is that the red cans are CONDUCTIVE.... you want to
be able to bleed off the static charge. If the can was
"non-conductive" the charge would tend to build up. Case in
point.... on a really dry day you can build up a static
spark from merely sliding off of your car seat. On a humid
or foggy day it isn't going to happen.
Also, keep in mind that you "ground" the gas hose to the
airplane before filling your tanks. That is so the hose and
your airplane are at the same potential. No sparks that
way.
oxygen.
What did you just say?? Kerosene is less volatile so is
more dangerous?? Tell you what... try this experiment for
me. Take a small dish of kerosene, about a cup, no more and
hold a lighted match above it. Vary the distance of the
match from 10" to 1/2" above the kerosene. Ok, did it
catch on fire??
Now, take another small dish with the same amount of auto
gasoline (oh, to add another variable, try it later with
Aviation Gas). Same dish, same match and Same distances
from the fuel. Did it catch on fire??
I STRONGLY suggest you use a very long match or otherwise
keep your hands at least two feet from the dishes. Also,
any injurys resulting from this experiment are solely your
responsibility.
Just curious
----Whaa Keen
--Zorro
Old March 26th 05, 06:51 PM
Juaquin Murrieta
catch on fire??
responsibility.
As usual, words just don't do it and my explanation above is
inadequate. Yes, Kerosene is less volatile. Because of that, there
are fewer hydrocarbon molecules leaving the surface and saturating
the air above the liquid. It turns out that this lower
hydrocarbon/oxygen ratio is combustible where that ratio in a gas can
holding gasoline is not combustible. With gasoline, it's more
volatile and therefore there are too many hydrocarbon molecules in the
air above the liquid. The kinetics aren't right for combustion.
Your example of putting some of these liquids on a plate is not the
same. That's not a closed container. It's exposed to the air and the
concentration of hydrocarbons just above the liquid will be high but
decrease as you move away and above the dish. You'll find a point
where the kinetics are perfect for combustion. In a "CLOSED"
container this is not the case. The hydrocarbon concentration in the
air above the liquid is fairly constant throughout the inside of the
container because it's trapped. With Kerosene and its lower
volatility than gasoline, this molecular ratio to oxygen is just
perfect for combustion. In a container partially filled with
gasoline, the air above the liquid is too saturated with gasoline
molecules for combustion to occur.
This is why airliners almost always burn upon crashing. For years
there has been a ton of research to build tanks that have honey
combing in them or other materials to impede the combustibility of the
air above the liquid fuel. All research to date has done very little
to reduce the probability of burning upon impact for kerosene filled
tanks
(jet fuel is essentially just kerosene).
Now, back to my question. I am not interested in web sites that talk
about filling gas cans in the back of pick ups. I am interested in
hearing from anyone who has actually witnessed or knows of someone who
has been involved in a combustion occurring from using a plastic or
metal gas can. My point is that I think the regulations on all of
this are probably just bull ****. I think there have been so few, if
any, real accidents involving this situation that the safety
regulations are overdone to the point of absurdity. Industry itself
drives a lot of this so they can sell newer containers. Look at the
propane industry over the last few years. Those *******s are always
changing something and getting a law passed so they can force us to
have to discard our older containers and buy new ones. I'm thinking
that this gas can stuff is about the same. The probability of a spark
causing ignition during fueling from one of these containers might be
more remote than being struck by lightening.
Thanks.
--Juaquin
Old March 26th 05, 07:40 PM
Denny
I have had a standing challenge for anyone to affirm that they,
themself, personally witnessed a fire start by a static spark from
refueling by hand from a plastic can, metal, glass, anything... To date
everyone keeps posting what the govt, or Chevron said, or his buddy who
knew a guy, yadda, yadda,,, The actual incident rate of fire sparked by
pouring gas from a 5 gallon plastic can has to be about as close to
zero and you can get, given the tens of millions of lawn mowers,
tractors, snowmobiles, motorcycles, etc., that are refueled by hand
from plastic cans every single day in the this country...
Just use common sense... Set the can on the wing and while holding it
reach down and unlatch the gas cap... Your body is the grounding
resistor that makes all the static charges equalize...
denny
Old March 26th 05, 08:12 PM
Roger
On Sat, 26 Mar 2005 15:58:42 GMT, (Juaquin
I know of several, but they were "way back when" and from metal cans
into metal funnels, with metal screens, into metal tractors. As I
said it was a long time ago as I haven't farmed since 1961
I think we should be careful using the word "ground" in this sense.
*Normally* there is only one really important electrical connection.
That is the one between the fuel source and the receptacle. IE the can
and the tank.
We normally refer to this as grounding and although technically not
correct it's as good as any in common usage.
The can, the operator, and the tank need to be electrically connected
together. Normally the true "ground" to earth ground doesn't mean
squat if the source, be it tank, can, or underground storage, is
electrically connected to the tank it is fueling.
The common point *earth* ground is used because it is handy AND it's a
back up means of protection in case the other means of electrical
connection are broken (as in opened)
There are some dynamics involved. Yes, gas can flow fast enough out
of a plastic or *metal* container (gas can) to create a spark. It's
surprising how little flow is required if you are really trying to
create one.
Yes, but as I said they were "way back when". No one was seriously
injured except in one case and that was not a fueling accident. It
depends on the concentration of the fumes in the tank and the noise
can be fairly loud, but the two I heard were mover a wwhistling and
very loud, "Fwapppp!".
The main danger is not *normally* the explosion per se, but rather
taking a bath in burning gas which can ruin your whole day.
"Sort of exploded?" Is that something like "just a little bit
pregnant. Not enough to notice, but just enough to make you nervous?"
The gas pump is no different than the can with the exception of the
volume and velocity of the gas coming out. That means it can develop a
charge faster than pouring. In this case the pump was probably
grounded to earth and the truck was not. Had the nozzle been
electrically connected to the truck or can no spark would have
occurred.
out.
Well, kinda, sorta, almost, but not quite. The reason is the
interface between the air and the gas fumes. There are two limits.
The Lower Explosive Limit (LEL) and the upper explosive limit (UEL).
You rarely see UEL used, but LEL is quite common. Some where your
cigarette is going to pass between those limits on the way in.
As an extreme, the LEL for Hydrogen of 4% by volume and I believe the
UEL is 96%. This is about as wide as you are going to get. Gas OTOH
has a much narrower range between the LEL and UEL. I've forgotten the
specific values but they are much narrower than Hydrogen. Still, you
can get a lot of bang out of the proper mixture.
oxygen.
This causes a dynamic reaction that creates a "Whooup" (sometimes
accompanied by a bang) sound with the air trying to get in and the gas
trying to get out.
I have put a lit "kitchen style" match directly into an open pail of
Kerosene without even a flash. When very close to the surface the
match did get a bit brighter, but there was no flash and the kerosene
put the match out.
I've seen the demonstration done with either the old JP-4 or Jet-A. I
Jet fuel has some additives like Benzene which are much more
flammable.
Been there and seen it, but not at an airplane.
There is an ever present danger of fuel ignition when ever fueling.
Proper fueling techniques should eliminate them.
www.rogerhalstead.com
Just curious
----Whaa Keen
--Zorro
Old March 26th 05, 10:53 PM
UltraJohn
Jeff wrote:
It is very well documented that there ilitigation with metal gas cans
being
a link to an article that also documents the problem occurring with
plastic
Jeff
Yes, they'd also like to make you think that cell phones will cause and
explosion while filling your tank. I'm thinking since a cell phone is a
duplex transceiver there is no antenna switching, no relays to arc so what
would cause an explosion? A watt or so of rf, not in my life!
These things come from our societies fascination with litigation! No one
wants to take responsibilities for their own screw ups! Most of the fueling
accidents I'd be willing to bet are from people arcing from themselves to
the car in dry cold conditions.
So use common sense, ground yourself to the fueling vessel and fueled vessel
then open the containers and do it!
John
off the soap box now!
Old March 26th 05, 11:08 PM
C J Campbell
"UltraJohn" wrote in message
k.net...
The Mythbusters actually tried to get a cell phone to cause an explosion,
even putting it inside a container of fuel and air the same ratio as in an
engine. No dice. In fact, there has never been an explosion that can be
verified as having been caused by a cell phone.
Yet you still see cell phone warnings at some fuel pumps, the vendors say
because they are concerned about liability. But if someone beats you up
because they believe those warnings, can you sue the gas company?
