Money for a new aircraft
Old March 26th 05, 10:52 PM
Default Money for a new aircraft
A little while back, I was browsing these newsgroups, just like you
are now, and came across an article similar to this that said you
could make thousands of dollars within weeks with only an initial
investment of $5.00 ! So I thought, "Yeah, right, this must be a
scam", like most of us, but I was curious, like most of us, so I kept
reading. Anyway, it said that you send $1.00 to each of the 5 names
and address stated in the article. You then place your own name and
address in the bottom of the list of #5, and post the article in at
least 200 newsgroups.(There are thousands) No catch, that was it.
So after thinking it over, and talking to a few people first, I
thought about trying it. I figured what I have got to lose except 5
stamps and $5.00, right?
Like most of us I was a little skeptical and a little worried about
the legal aspects of it all. So I checked it out with U.S. Post
Office(1-800-725-2161) and they confirmed that it is indeed lega!
Then I invested the measly $5.00................
\Well GUESS WHAT! !..... With in 7 days, I started getting money in
the mail! I was shocked! I still figured it end soon, and didn't give
it another thought. But the money just coming in. In my first week, I
made about $20.00 to $30.00 dollars. By the end of the second week I
had made total of over $1,000.00!!!!!! In the third week I had over
$10,000.00 and it's still growing. This is now my fourth week and I
have made a total of just over $42,000.00 and it's still comming in
........ It's certainly worth $5.00, and 5 stamps, I spent more than
that on the lottery!!
Let me tell you how this works and most importantly, Why it works....
also, make sure you print a copy of this article NOW, so you can get
the information of it as you need it. The process is very simple and
consists of 3 easy steps :
STEP 1 : Get 5 separate pieces of paper and write the following on
each piece of paper "PLEASE PUT ME ON YOUR MAILING LIST." now get 5
$1.00 bills and place ONE inside EACH of the 5 pieces of paper so the
bill will not be seen through the envelopes to prevent thievery. Next,
place on paper in each of the 5 envelopes and seal them. You should
now have 5 sealed envelopes, each with a piece of paper stating the
above phrase and a $1.00 bill. What you are doing is creating a
service by this. THIS IS PERFECTLY LEGAL!
Mail the 5 envelopes to the following addresses :
#1 Michael Henry
518 West College Ave.
Salisbury, MD 21801
U.S.A.
#2 Occupant
P.O. Box 54230
Houston, Tx.
77272-1193
U.S.A.
#3 Kevin Michael
1006 Abercorn Place
Sherwood, AR 72120
U.S.A.
#4 Chang
P.O.Box 502651
San Diego CA 92150-2651
U.S.A.
#5 Jeremy Nunn
C/- Post Office
Sandy Hollow
NSW 2333 Australia
STEP 2 : Now take the #1 name off the list that you see above, move
the other names up ( 5 becomes 4, 4 becomes 3, etc...) and add YOUR
Name as number 5 on the list.
STEP 3 : Change anything you need to, but try to keep this article as
close to original as possible. Now, post your mended article to at
least 200 newsgroups. (I think there are close to 18,000 groups) All
you need is 200, but remember, the more you post, the more money you
make! Don't know How post in the newsgroups? Well do exactly the
following :
FOR NETSCAPE USERS,
1) Click on any newsgroups, like normal. Then click on "To News",
which is in the top left corner of the newsgroups page. This will
bring up a message box.
2) Fill in the SUBJECT with a flashy title, like the one I used,
something to catch the eye!!!
3) Now go to the message part of the box and retype this letter
exactly as it tis here, with exception of your few changes. (remember
to add your name to number 5 and move the rest up)
4) When you're done typing in the WHOLE letter, click on 'FILE'
above the send button. Then, 'SAVE AS..' DO NOT SEND YOUR ARTICLE
UNTIL YOU SAVE IT. (so you don't have to type this 200 times :-)
5) Now that you have saved the letter, go ahead and send your
first copy! (Click the 'SEND' button in the top left corner)
6) This is where you post all 200! OK, go to ANY newsgroup
article and click the 'TO NEWS' button again. Type in your flashy
subject in the 'SUBJECT BOX', then go to the message and place your
cursor here. Now click on 'ATTACHMENT' which is right below the
'SUBJECT BOX'. Click on attach file then find your letter wherever you
saved it. Click once on your file then click 'OPEN' then click 'OK'.
If you did this right, you should see your filename in the 'ATTACHMENT
BOX' and it will be shaded.
NOW POST AWAY!!
IF YOU'RE USING INTERNET EXPLORER :
It's just as easy, holding down the left mouse button, highlight
this entire article, then press the 'CTRL' key and 'C' key at the same
time to copy this article. Then print the article for your records to
have the names of those you will be sending $1.00 to.
Next, go to the newsgroups and press 'POST AN ARTICLE' type in
your flashy subject and click the large window below. Press 'CTRL' and
'V' and the article will appear in the message window. **BE SURE TO
MAKE YOUR ADDRESS CHANGES TO THE 5 NAMES.**. Now re-highlight the
article andre-copy it so you have the changes..... then all you have
to do for each newsgroups is 'CTRL' and 'V' and press 'POST'. It's
that easy!!!
THAT'S IT! ALL you have to do is jump to different newsgroups and post
away, after you get the hang of it, it will take about 30 seconds for
each newsgroup! **REMEMBER, THE MORE NEWSGROUPS YOU POST IN, THE MORE
MONEY YOU WILL MAKE!! BUT YOU HAVE TO POST A MINIMUM OF 200 **
That's it! you will begin receiving money from around the world within
day's! You may eventually want to rent a P.O.Box due to the large
amount of mail you receive. If you wish to stay anonymous, you can
invent a name to use, as long as the postman will deliver it. ** JUST
MAKE SURE ALL THE ADDRESS ARE CORRECT. **
Now the WHY part :
Out of 200 postings, say I receive only 5 replies (a very low
example). So then I made $5.00 with my name at #5 on the letter. Now,
each of the 5 persons who just sent me $1.00 make the MINIMUM 200
postings, each with my name at #4 and only 5 persons respond to each
of the original 5, that is another $25.00 for me, now those 25 each
make 200 MINIMUM postings with my name at #3 and only 5 replies each,
I will bring in an additional $125.00! Now, those 125 persons turn
around and post the MINIMUM 200 with my name at #2 and only receive 5
replies each, I will make an additional $625.00! OK, now here is the
fun part, each of those 625 persons post a MINIMUM 200 letters with my
name #1 and the each only receive 5 replies, that just made me
$3,125.00!!! With a original investment of only $5.00! AMAZING! And as
I said 5 respones is actually VERY LOW! Average is probable 20 to 30!
So lets put those figures at just 15 responses per person. Here is
what you will make :
at #5 $15.00
at #4 $225.00
at #3 $3,375.00
at #2 $50,625.00
at #1 $759,375.00
When your name is no longer on the list, you just take the latest
posting in the newsgroups, and send out another $5.00 to names on the
list, putting your name at number 5 again. And start posting again.
the thing to remember is, do you realize that thousands of people all
over the world are joining the internet and reading these articles
everyday, JUST LIKE YOU are now!! So can you afford $5.00 and see if
it really works?? I think so... People have said, "What if the plan
is played out and no one sends you the money? So what! What are the
chances of that happening when there are tons of new honest users and
new honest people who are joining the internet and newsgroups everyday
and are willing to give it a try? Estimates are at 20,000 to 50,000
new users, every day, with thousands of those joining the actual
internet. Remember, play FAIRLY and HONESTLY and this will work. You
just have to be honest. Make sure you print this article out RIGHT
NOW, also. Try to keep a list of everyone that sends you money and
always keep an eye on the newsgroups to make sure everyone is playing
fairly. Remember, HONESTY IS THE BEST POLICY. You don't need to cheat
the basic idea to make the money!!
GOOD LUCK to all and please play fairly and reap the huge rewards from
this, which is tons of extra CASH. ** By the way, if you try to
deceive people by posting the message with your name in the list and
not sending the money to the rest of the people already on the list,
you will NOT get as much. Someone I talked to knew someone who did
that and he only made about $150.00, and that's after seven or eight
weeks! Then he sent the 5 $1.00 bills, people added him to their
lists, and in 4-5 weeks he had over $10k. This is the fairest and most
honest way I have ever seen to share the wealth of the world with
costing anything but our time!!! You also may want to but mailing and
e-mail lists for future dollars.
Please remember to declare your extra income. Thanks once again....
Old March 28th 05, 12:58 AM
Gumby
You are a ****ing idiot, crook, spammer, douchebag & overall blithering
moron.
Old March 28th 05, 02:56 AM
Casey Wilson
"Gumby" wrote in message
You are a f......
PLONK!!
Old March 28th 05, 06:59 AM
tony roberts
moron.
Don't hold back - tell him how you really feel.
Tony Roberts
PP-ASEL
VFR OTT
Night
Old March 31st 05, 06:36 PM
GEG
How stupid is this?
Old April 2nd 05, 03:56 AM
Bob Noel
GEG wrote:
How stupid is this?
almost as stupid as the TSA.
Bob Noel
looking for a sig the lawyers will like
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
