Cirrus Deploys Chute Safely
Old September 22nd 04, 04:32 PM
m alexander
Default Cirrus Deploys Chute Safely
http://www.modbee.com/local/story/91...10080739c.html
Old September 22nd 04, 05:12 PM
C J Campbell
"m alexander" wrote in message
et...
Yet another Cirrus flying in coffin corner at high altitude in turbulence.
It seems to me that if airline pilots can be taught to do this without
falling out of the sky, then surely a Cirrus pilot can be taught the same,
or at least, like the rest of us, just stay out of there.
Old September 22nd 04, 06:20 PM
Dude
This sounds simillar to the Canadian story. Why can these guys not recover
from the spins if they are so high?
et...
Old September 22nd 04, 06:45 PM
Corky Scott
On Wed, 22 Sep 2004 08:12:30 -0700, "C J Campbell"
How can you discern that from the story? Nothing in the text says
that the airplane was at high altitude, only that it got into a spin
due to extreme turbulence. Did you have access to additional
information not given in the story that the posted URL gives you?
My question would be: why was the pilot flying the airplane in a
thunderstorm? Was he flying in clouds and encountered an embedded
stormcell?
Corky Scott
Old September 23rd 04, 03:35 AM
C J Campbell
"Dude" wrote in message
recover
The Cirrus cannot recover from spins. Here is a quote from the SR22 manual:
Spins
The SR22 is not approved for spins, and has not been tested or
certified for spin recovery characteristics. The only approved and
demonstrated method of spin recovery is activation of the Cirrus
Airframe Parachute System (See CAPS Deployment, this section).
Because of this, if the aircraft “departs controlled flight,” the CAPS
must be deployed.
While the stall characteristics of the SR22 make accidental entry into a
spin extremely unlikely, it is possible. Spin entry can be avoided by
using good airmanship: coordinated use of controls in turns, proper
airspeed control following the recommendations of this Handbook, and
never abusing the flight controls with accelerated inputs when close to
the stall (see Stalls, Section 4).
If, at the stall, the controls are misapplied and abused accelerated
inputs are made to the elevator, rudder and/or ailerons, an abrupt wing
drop may be felt and a spiral or spin may be entered. In some cases it
may be difficult to determine if the aircraft has entered a spiral or the
beginning of a spin.
• WARNING •
In all cases, if the aircraft enters an unusual attitude from
which recovery is not expected before ground impact,
immediate deployment of the CAPS is required.
The minimum demonstrated altitude loss for a CAPS
deployment from a one-turn spin is 920 feet. Activation at
higher altitudes provides enhanced safety margins for
parachute recoveries. Do not waste time and altitude trying to
recover from a spiral/spin before activating CAPS.
Inadvertent Spin Entry
1. CAPS
...... Activate
Old September 23rd 04, 03:36 AM
C J Campbell
"Corky Scott" wrote in message
turbulence.
same,
stormcell?
http://www.duluthsuperior.com/mld/du...or/9723097.htm
Old September 23rd 04, 04:46 AM
C.D.Damron
"C J Campbell" wrote in message
Because of this, if the aircraft "departs controlled flight," the CAPS
must be deployed.
Sounds like legal-speak to me. I'm am willing to bet that Cirrus has spun
the hell out of that design with pleasing results.
Old September 23rd 04, 05:26 AM
Orval Fairbairn
In article YNq4d.240836$mD.16837@attbi_s02,
must be deployed.
That is apparently what cost Astronaut Gorden Fullerton his life, when
he was testflying a Cirrus.
Old September 23rd 04, 06:41 AM
C J Campbell
"C.D.Damron" wrote in message
news:YNq4d.240836$mD.16837@attbi_s02...
must be deployed.
spun
Actually, no pilot has ever reported recovering from a spin in a Cirrus. It
is not for lack of trying. There are numerous reports of Cirrus aircraft
crashing (or they would have crashed if CAPS had not been deployed) after
the pilots entered a spin, however.
Old September 23rd 04, 02:21 PM
Dave Hyde
That will come as a surprise to him. :-) You're thinking of
Bob Overmyer, but he was killed in a VK-30, which was a completely
different airplane, a kit put out by Cirrus before they certificated
the SR series. Fullterton is still alive, BTW.
Dave 'program' Hyde
Ballistic chute saves 4 souls Bob Babcock Home Built 28 April 27th 04 10:29 PM
