Std 102 water ballast plug
Old April 10th 05, 08:27 PM
Tom Dukerich
Default Std 102 water ballast plug
The plug for the water ballast is stuck in up position. I've reached
in and tried to operate the lever by hand, but it will not move. Any
suggestions for getting it operational?
Thanks - Tom
Old April 10th 05, 10:35 PM
John Sinclair
Penetrating oil, inside and out + heat gun applied
to valve. Work it gently until it starts to move.
JJ
I've reached
not move. Any
Thanks - Tom
Old April 12th 05, 02:42 AM
were the wing to fuselage linkages in the right position when the wings
were
put on the fuselage - if the dump valve was closed in the wing and the
dump
lever in the fuselage was open - you must take the wings off and put
everything
"closed" and reassemble.
Old April 12th 05, 06:10 PM
Tom Dukerich
There are no valves in the wings. They both feed to a drain plug in the
fuselage belly.
were
dump
everything
Induction System Water Problem Mike Spera Owning 1 January 30th 05 06:29 AM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 04:14 PM
Schemp Hirth water ballast dump valves tango4 Soaring 14 September 2nd 04 08:13 PM
astir cs-77 water ballast pete83 Soaring 4 May 27th 04 06:21 AM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 10:41 AM
