Check Valve Repair?
Old April 14th 05, 04:57 PM
Larry
Default Check Valve Repair?
I have a fuel line check valve between my axillary electric fuel pump
and the mechanical one.(I don't know if it is a "bleeder" type..not
sure what that means). Anyway I discovered a fuel leak during my
pre-flight when I turned on my backup electric fuel pump on my 0200A
Continental engine. The fuel pressure backed up to the outflow on the
mechanical fuel pump where the leak was found at the outflow side fuel
fitting. I figure this could only happen if the check valve is not
doing its job unless a little back flow is normal. Anyway I'm going to
replace the fitting as the sleeve is the source of the recent leak. Are
check valves servicable? What typically goes wrong with thim? Thanks
for your thoughts on the matter..
Larry
Old April 15th 05, 07:32 AM
abripl
A replacement check valve is about $40 from Wicks or Spruce.
fuel
to
Are
Larry
Calibrate? Repair? Adjust? RST Engineering Owning 3 April 4th 05 02:41 PM
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 11:20 PM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 04:09 AM
WTB: ASW 27A water valve Peter Van Camp Soaring 0 April 28th 04 11:37 PM
Q: Disecting a cut-off valve? Michael Horowitz Home Built 0 March 6th 04 02:47 PM
