Skew-T charts on Dr. Jacks ?
Old April 19th 05, 03:27 AM
Doug Snyder
Default Skew-T charts on Dr. Jacks ?
Can anyone point me to a reference that will help me interpret the
skew-T charts on Dr. Jack's? I realize the information may be on the
site but I haven't found it. Soundings aren't available so I'd like to
know what I can determine from the available info.
Doug
Old April 19th 05, 05:36 PM
Bruce
Doug
Try - http://www.theweatheroutlook.com/com...cle.asp?id=182
Old April 19th 05, 06:17 PM
Doug Snyder
That looks like enough to keep me busy for awhile.
Doug
Old April 25th 05, 08:36 PM
Robert Ehrlich
Therw is a little unaccuracy in the text cited above, when it says:
"As the temperature drops the dew point remains constant, because the
total volume of water in the parcel is (basically) unchanged."
The meaning of the term "dew point" in this context is not clear, if
it means "temperature of the dew point", this is not true. The
temperature at which the water vapor will condense is related to its
partial pressure. The thing which remains constant while the parcels
ascends is the mass of water it contains, however, due to its expansion,
the partial pressure of water vapor drops, so the temperature at which
it will condense is lower than at ground level. This is why all these
diagrams have a network of lines usually called "mixing ratio lines",
each such line gives the relationship between total pressure (or
equivalently altitude) and temperature at which a parcel with this
mixing ratio (i.e. mass of water per mass of air, the thing which
remains constant) will condense. As expected from previous
considerations, along such a line the temperature drops as pressure
drops or altitude raises.
However the text cited above later correctly describes the use of these
mixing ratio lines.
Ebay Auction Jeppesen VHS (4) tapes collection: Enroute Charts, IFR Emergencies, Departures & Arrivals, Approach Charts Cecil Chapman Products 0 February 9th 05 04:09 AM
RNAV Enroute CHarts John R. Copeland Instrument Flight Rules 0 September 20th 04 04:33 PM
how to get NACO online charts conveniently? Dave Butler Instrument Flight Rules 41 June 16th 04 04:14 PM
Jepp Charts - Subscription Only? Peter Gibbons Instrument Flight Rules 8 November 8th 03 03:01 PM
NACO charts - why have a reference circle? Bob Gardner Instrument Flight Rules 5 September 6th 03 02:15 PM
