On the lighter side
Old April 20th 05, 01:52 AM
Soar Stanton MN
Default On the lighter side
OK - a bit of a Soaring spin on some real-life pilot/mechanic
communications:
Commercial Glider operation -
Commercial Pilot notes in Daily Log to local A&P about maintenance issues
with the glider that requires his immediate attention:
Pilot Entry: Glider seems to have a new rattle.
A&P: Yes, it was a birthday gift from the factory.
Pilot Entry: Tow release sticking - almost needs replacing.
A&P: Almost replaced tow release.
Pilot Entry: Many Dead bugs on leading edge of wing.
A&P: Live bugs on back-order.
Pilot Entry: Divebrakes only provide a 300 feet per minute descent.
A&P: Cannot reproduce problem on ground.
Pilot Entry: Evidence of leak in main landing gear.
A&P: Evidence removed.
Pilot Entry: Dive brakes very noisy, not sure which wing.
A&P: One side now disconnected, please retest.
Pilot Entry: Audio Vario volume unbelievably loud.
A&P: Volume set to more believable level.
Pilot Entry: Push to talk switch rather sticky.
A&P: Found candy bar near rudder pedals.
Pilot Entry: Ballast system seen leaking.
A&P: Look away next time, it's rude to watch.
Pilot Entry: Suspected crack in canopy.
A&P: Suspect you're right.
Pilot Entry: Tow-pilot reports cylinder missing at full throttle.
A&P: All cylinders found after brief search under cowling.
Pilot Entry: New 2-place glider seems to act funny.
A&P: Glider warned to get serious.
Pilot Entry: Glide Computer hums.
A&P: Reprogrammed glider computer with lyrics.
Pilot Entry: Noise coming from gear-door area. Sounds like a midget pounding
on something with a hammer.
A&P: Took hammer away from midget.
Pilot Entry: Relief system has developed a rather stale odor.
A&P: Relief system never installed.
Pilot Entry: Female passenger complained she was very uncomfortable in the
front seat today.
A&P: Have her ask for a different pilot next time.
Pilot Entry: The old control stick squeak is back.
A&P: I kinda knew it couldn't stay away.
Pilot Entry: Brakes stopped working.
A&P: Management says they will consider disciplinary arction.
Pilot Entry: My glider has developed a sloppy canopy fit. I think I have a
screw loose.
A&P: I couldn't agree more.
Airmen at Osan switching from M16A2 to lighter M4 carbine, By Franklin Fisher, Stars and Stripes Otis Willie Military Aviation 0 April 29th 04 05:07 AM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 05:55 PM
Piper doors, why the passenger side? Nathan Young Owning 58 September 29th 03 02:38 AM
Why crabbing is correct and side slipping isn't (was Flying Technique Question of the Day Eric Greenwell Soaring 12 September 18th 03 08:21 AM
FS: Piper Side Window (New) JimC Aviation Marketplace 0 August 10th 03 01:19 PM
