GDL-49 and Levels of Radar Returns
Old April 23rd 05, 08:20 PM
O. Sami Saydjari
Default GDL-49 and Levels of Radar Returns
As I was coming into Grand Rapids (KGRR) yesterday, the controller
announced that there was a "level 5" return (or perhaps she said "cell")
on final to runway 8, so I was vectored to 35 where there were mostly
"just level 4" stuff. So, forgive my ignorance, but where are these
levels defined? I assume they have to do with what sort of radar return
they get off a cloud and therefore has to do with rain intensity. Does
a level 5 return imply that a thunderstorm is likely to be generating it?
Also, I have a GDL-49 Satellite Data Link Transceiver linked to my
Garmin 430 display. I understand (and now have seen) that these things
just are not adequate to locate big cells. Rather, they show large
areas of showers. Are these based on satellite imagery, or from
aggregated ground station data or what?
Also, how to the radar levels (1 thru 6?) relate to the colors shown on
a GDL-49 display on a Garmin 430? Does red equal level 5 or level 6? I
think only have red, yellow and green...so it seems there are not
enough colors to show 6 levels.
-Sami, N2057M, Piper Turbo Arrow III
Old April 24th 05, 10:20 AM
You might try checking the AIM, for starters. Then, perhaps, the IHB.
Old April 24th 05, 03:49 PM
O. Sami Saydjari
Tim,
Chapter 1, section 1 of the AIM would seem to be most appropriate for
this question, and I have found no references to radar echoes. If you
have a pointer to the information that you think answers my question,
that would be helpful.
Please forgive my ignorance, but I do not know the acronym "IHB."
Please expand.
I have also tried Circular AC-00-6A, and did not find it.
I would also note that note of these sources is likley to answer the
questions of color mapping on a GDL-49/Garmin 430.
-Sami
Old April 24th 05, 03:51 PM
Gerry Caron
Rod Machado's column in the latest AOPA Pilot covers the subject very well.
Gerry
"O. Sami Saydjari" wrote in message
they get off a cloud and therefore has to do with rain intensity. Does a
Also, I have a GDL-49 Satellite Data Link Transceiver linked to my Garmin
430 display. I understand (and now have seen) that these things just are
not adequate to locate big cells. Rather, they show large areas of
showers. Are these based on satellite imagery, or from aggregated ground
Also, how to the radar levels (1 thru 6?) relate to the colors shown on a
think only have red, yellow and green...so it seems there are not enough
Old April 24th 05, 05:29 PM
O. Sami Saydjari
In googling around a bit, I found the following:
At: http://www.weatherzone.com.au/misc/g...y.jsp?letter=V
"Video Integrator and Processor, which contours radar reflectivity (in
dBZ) into six VIP levels:
• VIP 1 (Level 1, 18-30 dBZ) - Light precipitation
• VIP 2 (Level 2, 30-38 dBZ) - Light to moderate rain.
• VIP 3 (Level 3, 38-44 dBZ) - Moderate to heavy rain.
• VIP 4 (Level 4, 44-50 dBZ) - Heavy rain
• VIP 5 (Level 5, 50-57 dBZ) - Very heavy rain; hail possible.
• VIP 6 (Level 6, 57 dBZ) - Very heavy rain and hail; large hail possible."
At:
http://www.garmin.com/manuals/773_Ga...deAddendum.pdf
Ok, now, from the Nextrad intensity table on page 13 of the Garmin
"400/500 Series garmin Options Displays", I learned:
GREEN means 5-30 dBZ
YELLOW means 30-55 dBZ
RED means 55-75 dBZ
So...
Green is VIP Level 1
Yellow is VIP Levels 2,3,4
Red is VIP levels 5 and 6
The radar appears to come from an aggregation of ground NEXTRAD sites,
that is beamed up via satellite based on user request messages.
Old April 24th 05, 05:44 PM
John Clonts
"O. Sami Saydjari" wrote in message ...
As I was coming into Grand Rapids (KGRR) yesterday, the controller announced that there was a "level 5"
return (or perhaps she said "cell") on final to runway 8, so I was vectored to 35 where there were mostly
"just level 4" stuff. So, forgive my ignorance, but where are these levels defined? I assume they have to
do with what sort of radar return they get off a cloud and therefore has to do with rain intensity. Does a
By the way, when you flew through the "just level 4 stuff", how did you find the ride?
Cheers,
John Clonts
Temple, Texas
N7NZ
Old April 24th 05, 07:58 PM
O. Sami Saydjari
Surprisingly, the most I experienced was light turbulence. The landing
was uneventful. At the same time, I expect I was pretty lucky and
probably will actively avoid landing in these sorts of conditions in the
future.
My NEXTRAD showed "green" so I was unconcerned going in. It was only
from approach that I started hearing about level 4 and leve 5 stuff
around the airport. Had I known, I would have diverted north.
-Sami
Old April 25th 05, 01:40 AM
Newps
That's pretty funny because even the airlines ain't flying thru a level
four return on final.
Old April 25th 05, 02:03 AM
Jim Burns
Sami, you've hit upon the answer to your question, and one thing to keep in
mind is that radar don't know squat about whether the rain is from a
thunderstorm or not, all it sees is the "reflection" of the precip, the
higher the number, the higher the bounce back. Granted, a thunderstorm that
is full of rain and hail will definately produce a higher return.
Additional information about the current conditions vs. forecast conditions
combined with front locations, movement, direction, sigmets, and airmets
should provide you with a more complete picture of what your Data Link is
showing you.
Over the past couple weeks, we've had two totally different low pressure
systems move through Wisconsin. The first contained a leading edge of
thunderstorms, high winds and heavy rain. The last contained high winds,
heavy rain, but no thunderstorms. The echoes for both storms were level 2's
and 3's. The difference between the two storms was the amount of lifting
action available. The first storm occurred during a period of relatively
hot and unstable conditions. The second occurred during cool and more
stable conditions, it was much less violent but the radar returns were the
same.
Jim Burns
possible."
At:
RED means 55-75 dBZ
So...
it?
Old April 25th 05, 03:59 AM
O. Sami Saydjari
mostly "just level 4" stuff.
That is pretty odd. I am sure she said level 4. The rain seemed only
moderate to me and visibility seemed like it was 2-3 miles. Perhaps I
got lucky. How sure are you that airlines do not land in level 4? If
so, it seems that they would advise a light aircraft to divert or hold.
IGC-approval levels for some types of Flight Recorders Ian Strachan Soaring 42 March 19th 05 06:42 PM
Flight Levels?? Chuck Dreier Instrument Flight Rules 6 February 14th 05 05:34 PM
Flight planning at the lower flight levels Peter R. Piloting 2 March 16th 04 03:39 AM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 03:13 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
