Surface Corrosion?
Old May 1st 05, 05:26 PM
Joaquin Murrieta
Default Surface Corrosion?
I'm working on a little aluminum airplane that has some surface
corrosion just under the paint in a couple places.
What do you guys use as a treatment to stop the aluminum corrosion? I
remember 30 years ago using phsophoric acid then a zinc chromate
converstion treatment. Is this still the best technique to stop the
corrosion?
I need to just abate the current corrosion from expanding. What do
you guys recommend?
BWB
Old May 1st 05, 05:55 PM
Clay
Etch and alodine is still the best way.
Use a 3-M 7447 Scotch Brite pad to help remove the corrosion.
A good epoxy primer followed by topcoat and you should have the problem
solved.
Old May 3rd 05, 02:19 AM
Joaquin Murrieta
On 1 May 2005 08:55:26 -0700, "Clay"
solved.
THanks
Corrosion Proofing Clay Owning 7 April 22nd 05 01:03 AM
painted airtight window screen as a "surface" Allan Morrison Home Built 3 February 19th 05 04:40 AM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 04:36 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 02:31 AM
Corrosion X Applicators Hankal Owning 5 July 7th 03 07:07 PM
