Glue for bows?
Old May 4th 05, 04:21 AM
Termite
Default Glue for bows?
I'm trying to figure out which glue to use for wingtip bow laminating. I've
been using aerolite up to this point for my woodwork, bu tI'm told this is
unsuitable for bows due to it's fast setting time. I'm thinking T88, but am
open to suggestions. naturally it has to be strong, but I also ned it to be
relatively easy to work when i'm laminating (first time to try this, so
i'll need time) and it has to be workable when i'm shaping the lamination
when it's cured.
suggestions?
Old May 4th 05, 03:41 PM
jerry wass
when it's cured.
suggestions?
Can't go wrong with T-88!
Old May 5th 05, 10:34 AM
Simon Bugg
I've
am
be
when it's cured.
suggestions?
T88 should be good especially if low temperature is a problem.
I used a FGI epoxy R-180 which is similar to West System.
http://www.keypoint.com.au/~sab/construct/bowa.jpg
http://www.keypoint.com.au/~sab/construct/bowb.jpg
The laminations are 2mm thick by about 30mm wide and the whole bow is
about 1200mm wide by 300mm high. I can't remember how much I allowed
for spring-back, but I could probably find out.
Plenty of working time provided you have all the bits cut and ready
to go before you mix the glue (a practice run doesn't hurt either).
Simon
Old May 5th 05, 06:35 PM
ORVAL FAIRBAIRN
I've
am
be
when it's cured.
suggestions?
Simon
If you glue the strips on a form, there should be very little springback.
Remove _'s from email address to talk to me.
Old May 6th 05, 12:55 AM
Termite
ORVAL FAIRBAIRN
sednews
laminating.
I've
this is unsuitable for bows due to it's fast setting time. I'm
thinking T88, but
am
it to
be
this, so i'll need time) and it has to be workable when i'm shaping
the lamination when it's cured.
suggestions?
Simon
springback.
that's waht I thought. I've only done one lamination before (it didn't go
well) and it had a fairly severe curve at one point and in spite of my poor
clamping, it pretty much stayed the shape of the mold.
Old May 6th 05, 04:51 AM
Highflyer
"Termite" wrote in message ...
I've
am
be
when it's cured.
suggestions?
For many MANY years we have used resorcinal resin. Urea resin works well
also but it isn't quite as durable. Used both of them for water skis fifty
years ago and they still work. The skis too! :-)
Highflyer
Removable glue Lou Home Built 2 April 14th 05 06:57 AM
Glue question [email protected] Owning 1 December 6th 04 03:25 PM
Glue for wing step grippy thingies Steven Barnes Owning 6 November 28th 04 09:56 PM
Drywall Gussets Veeduber Home Built 5 October 27th 03 09:03 PM
Qn: Casein Glue recognition Vassilios Mazis Soaring 0 August 20th 03 10:00 PM
