CNC or Laser cut instrument panel
Old October 12th 04, 09:41 PM
Bill Daniels
Default CNC or Laser cut instrument panel
I need a small ( approx 18" square ) panel cut for an experimental
sailplane. Can anybody suggest a good source?
Old October 13th 04, 01:40 AM
Errol Groff
If you can send me a drawing (dimensioned sketch is OK) I can
probably help you out.
This is the sort of project that is a good learning tool fro my
students.
Anyone else who needs similar work please take note!
Costs will be far less than sending it out to a commercial machine
shop.
Accurate is our forte. Fast is not, so plan far ahead!
Errol Groff
Instructor, Machine Tool Department
H.H. Ellis Regional Technical School
Danielson, CT 06239
860 774 8511 x1811
On Tue, 12 Oct 2004 19:41:28 GMT, "Bill Daniels"
Old October 13th 04, 02:49 AM
Ross Oliver
Have a look at this web site:
www.emachineshop.com
I have not tried them yet, but the idea looks cool.
Old October 13th 04, 07:16 PM
JohnT.
Also consider having it water jetted. Like laser cut, but uses a high
pressure jet of water with abrasives in it.
John
Old October 13th 04, 07:31 PM
Bill Daniels
"JohnT." wrote in message
John
At this point, I would consider anything. I've been talking to some of the
dumbest phone sales people I can imagine. I've e-mailed the CAD file to 20
or so firms that advertise "custom panels" and, so far, no replies except
for one local CNC shop that quoted $855 for the 9-hole 18" panel in .125"
sheet.
Bill Daniels
Old October 13th 04, 07:58 PM
Richard Isakson
"Bill Daniels" wrote ...
20
sheet.
This is a homebuilt group. Have you considered building it yourself?
Rich
Old October 13th 04, 08:15 PM
Bill Daniels
"Richard Isakson" wrote in message
20
except
..125"
sheet.
Rich
Yes. I have made several panels but the CNC or laser cut panels are so much
higher quality than what I can make with a bandsaw, drill press and sander.
Bill Daniels
Old October 13th 04, 08:21 PM
W P Dixon
I was wondering the same thing myself , a panel is not hard to make at all.
If you have built an airplane the panel should be about the easiest part.
Are you planning on building this panel out of a special material? If it's
metal I would do it myself.
Patrick
20
except
..125"
sheet.
Rich
Old October 13th 04, 09:12 PM
Bill Daniels
The panel has to be .125" 7075 because it is a structural member. This is
NOT easy stuff to cut.
The last time is did this, I used a milling machine with a fly cutter to
make the instrument holes. Now all I have is a drill press. The tools that
I would need to buy to do this simple job will cost more than the job
'should' cost from a CNC or waterjet shop.
bildan
"W P Dixon" wrote in message
all.
Patrick
of
to
20
except
.125"
sheet.
Rich
Old October 13th 04, 11:01 PM
Morgans
"Bill Daniels" wrote in message
news:g6fbd.251368$3l3.188348@attbi_s03...
that
bildan
Aluminum can be cut on ANY woodworking tool, so I would cut it with a table
saw, (or radial arm) slightly oversize, then run the edge across the jointer
(or router table) to clean up the edge, if it has to be beautiful. The
holes could be cut with a high quality hole saw (under 40 bucks), and you
could make a template for the mounting holes, and you would be all set. Not
that hard, is it?
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.776 / Virus Database: 523 - Release Date: 10/12/2004
Instrument mounting question Rob Turk Home Built 4 July 19th 04 11:33 PM
Panel Lights - Need Help Barnyard BOb - Home Built 2 May 29th 04 08:51 PM
Panel lighting Corky Scott Home Built 5 March 6th 04 01:22 AM
Aluminum instrument panel finish? Richard Riley Home Built 31 February 4th 04 03:09 AM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 10:27 PM
