cvjetkovic ca-65 skyfly- plywood spar?
Old October 16th 04, 06:55 AM
patrick mitchel
Default cvjetkovic ca-65 skyfly- plywood spar?
A friend was given a reference to the use of plywood as a spar in the ca-65
skyfly. Was unaware of the use of ply as a spar in aircraft. Perhaps a
laminated spar with all the veneers running the same direction, but with
half running parallel to the chord????? Anyone have knowledge of said
homebuilt? Thanks Pat
Old October 16th 04, 03:52 PM
Hatz Lyman C
I am not familiar with the ca-65. It is common to use plywood in I-beam and
Box type spar construction.
Lyman
Old October 16th 04, 06:07 PM
Cy Galley
Use plies at a 45°
"patrick mitchel" wrote in message
ca-65
Old October 16th 04, 06:26 PM
Dan Thomas
"patrick mitchel" wrote in message ...
Probably they're referring to use of plywood in the spar structure.
Many wooden airplanes use built-up spars in which lumber is used to
carry the tension and compression loads, and plywood is used to keep
the lumber in its proper place. My Jodel has a box-type spar making
extensive use of plywood, with the face veneers running in various
directions to take maximum advantage of the ply's strength. That spar
carries all the wings loads: lift, drag and torsion. It's the only
spar in the wing, and is the single most complicated part in the
airplane. And the strongest.
Dan
Marske spar workshop Marske Flying Wings Home Built 0 October 14th 03 05:53 PM
Carbon Spar design and construction workshop Marske Flying Wings Home Built 0 September 18th 03 06:47 PM
Substitute for Mahogany plywood Kelvin & Janice Rempel Home Built 1 September 5th 03 09:02 PM
