Fixing screw holes in fabric
Old May 18th 05, 04:01 AM
Brian Huffaker
Default Fixing screw holes in fabric
Its annual time for the Starduster, and I was wondering about the
screws that hold on the inspection covers. Around each inspection hole,
there is a thickened area in the fabric cover that the screws go into. The
holes have become stripped out over time, and screws won't stay in.
Is there some kind of epoxy or something that could be used to fill in
the holes to be redrilled? None of the current members of the
partnership know much about fabric, so I thought I'd ask here.
Brian Huffaker, DSWL )
RV-8A Installing seat nutplates
Starduster Too Flying.
Old May 18th 05, 08:35 AM
Ed Sullivan
On Wed, 18 May 2005 02:01:52 +0000 (UTC), Brian Huffaker
If these are the circular type inspection covers and the thickened
area you refer to is a plastic ring cemented to the fabric, you might
just rotate the cover to a new position and drill a small pilot hole
and start the screws in the new position.
Ed Sullivan
Old May 18th 05, 05:39 PM
Brian Huffaker
No, these are square. It doesn't look like plastic to me.
Brian Huffaker
Old May 18th 05, 06:36 PM
Lou
If I recall, this is sold by Aircraft Spruce, what do they say?
If the material that it screws into is wood then just epoxy in enough
wood to re-drill and screw.
Any reason you can't make new rings and glue them on top of the old?
Or just epoxy new parts over the old inside the fabric?
Old May 21st 05, 03:16 AM
Baby Lakes
Perhaps you could slip a tinnerman nut over the screw hole - this would
provide a permanent and replacable fix
Archer stabilator jack screw play Mike Noel Owning 7 June 5th 04 09:02 AM
Screw hold repair in fabric? Brian Huffaker Home Built 11 May 29th 04 03:07 AM
Fabric repair D.A.L Home Built 0 April 27th 04 08:17 PM
Fabric Work Doug Home Built 9 January 26th 04 04:31 AM
Need to learn dope and fabric work David Hill Restoration 5 October 9th 03 02:52 AM
