Can Harriers ground-taxi backwards?
Old May 21st 05, 02:30 PM
Guy Alcala
Default Can Harriers ground-taxi backwards?
Hopefully Frijoles or some other current or former Harrier
type can answer this (whatever happened to Cecil Turner?).
Using braking stop it would seem at least theoretically
possible, but I don't know if there were other problems that
prevented it (hot gas re-ingestion/FOD, light on the wheels,
etc). Assuming it is doable and NATOPS allows it, is/was it
done rarely/infrequently/routinely on an LPH/LHA/LHD? I was
just wondering if it were possible to taxi cross-deck and
get lined-up, then backup to maximise T/O run, thus allowing
more a/c to be launched in a short period of time than if it
were necessary to use deck tractors for positioning. Or is
the deck wide enough and the maximum angle of the Harrier's
nosewheel steering gear great enough that it can taxi aft
and then essentially make a U-turn at the aft end of the
deck, wasting little or no T/O run? TIA,
Guy
Ground Stops and Ground Delay Programs [email protected] Piloting 1 February 18th 05 02:29 AM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 06:11 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 06:21 PM
