Butterfly Display V4.0 intermittent FLARMnet ID display - V4.1x3
Old March 17th 21, 10:18 PM posted to rec.aviation.soaring
Dave Nadler
Default Butterfly Display V4.0 intermittent FLARMnet ID display - V4.1x3
Hi All - I've found and fixed a couple more old bugs including this one.
Could use some help testing this prior general official release!
Download from link below, unzip, and load into Butterfly via your
PowerFLARM. If you're able to help test, PLEASE let me know if you've
loaded OK, and this bug fixed. And of course other bugs noticed...
Best Regards, Dave
http://www.nadler.com/backups/20210124_bfd_4_1x3.zip
Old March 27th 21, 08:58 PM posted to rec.aviation.soaring
Tim Taylor
Best Regards, Dave
Dave,
Uploaded OK today. I will let you know when I can confirm functionality. Thank you for working on this.
Tim
Old April 3rd 21, 08:34 PM posted to rec.aviation.soaring
Craig Funston[_3_]
Best Regards, Dave
Dave,
Tim
Dave,
The update loaded just fine. I'll let you know if I run into any squawks. Thanks for your work on this!
Craig
JN
Old April 12th 21, 12:49 AM posted to rec.aviation.soaring
Tim Taylor
Dave,
Everything worked well yesterday, I could see Flarm ID. Thank you for the update. Also, thanks for adding the PEV function. I did not know it was added until I downloaded the flight. I will have to test it next flight.
Tim
Old April 16th 21, 12:27 AM posted to rec.aviation.soaring
Brian[_1_]
On Sunday, April 11, 2021 at 4:49:29 PM UTC-6, Tim Taylor wrote:
Dave,
Tim
Agreed seem to work well for us on our Flight Monday. Also like the new features as well.
Thank You
Brian Case
LS6 "GG"
New Butterfly Display Software 3.2 Marc - Butterfly Avionics Soaring 36 March 8th 15 09:16 PM
FS: Flarm Butterfly 57mm Display $150 joesimmers[_2_] Soaring 0 February 24th 14 02:27 PM
New Butterfly Display Software 3.2.1 released Marc - Butterfly Avionics Soaring 27 August 28th 13 03:11 PM
Flarm Butterfly display [email protected] Soaring 10 May 6th 13 06:40 PM
Butterfly external display questions Andy[_1_] Soaring 30 October 15th 12 08:20 AM
