Corsairs with JATO?
Old May 25th 05, 03:39 AM
Kyle Boatright
Default Corsairs with JATO?
Was JATO used operationally by Corsairs operating off of carriers in WWII?
I just saw a film clip, purportedly from the invasion of Iwo Jima, of a
Corsair taking off from a carrier deck with JATO assistance. I have never
seen or heard of Corsairs using JATO before, and am wondering if JATO was
*really* used on operational Corsairs, or if the History Channel simply
spliced a neat looking clip into their Iwo Jima footage?
Thanks in advance.
KB
Old May 25th 05, 04:17 PM
Charlie Wolf
From this web site:
http://www.vectorsite.net/avf4u.html
By the beginning of 1945, the Corsair was a full-blown "mudfighter",
performing strikes with high-explosive bombs, napalm tanks, and HVARs.
It was a prominent participant in the fighting for the Palaus, Iwo
Jima, and Okinawa, with the ground-pounders calling it the
"Sweetheart" for its welcome services when things were getting nasty.
In the last months of the conflict, the F4U also carried the oversized
29.8 centimeter (11.75 inch) "Tiny Tim" unguided rocket on the
wingroot pylons for cracking Japanese strongpoints. Experiments were
performed in 1944 with an old F4U-1 with "jet assisted take-off
(JATO)" gear, featuring a small solid-fuel rocket attached on the
fuselage just behind each wingroot, to allow the Corsair to get off
the ground more easily with heavy loads, but it appears that JATO was
rarely, if ever, used in service with the Corsair.
Regards,
On Tue, 24 May 2005 21:39:04 -0400, "Kyle Boatright"
Thanks in advance.
KB
Old May 25th 05, 05:29 PM
R Leonard
Actually, yes they did, at least once. My father, a fighter pilot with
no little experience and then assigned to ComFAirWest after action at
Coral Sea, Midway, and in the Solomons, was the pilot involved with
testing the JATO equipped F4U-1D, Bu No 56048.
This just another idea tested to speed up launches. Prior to the F4U
test it was also tested using an F4F-3 in l943, but as far as I know
only in land based take offs, not launching from carriers. The JATO
units for those tests was primitive, but did provide enough uumph to
push the Wildcat to a shorter take off run. (Not sure who was the
pilot who did the F4F tests.)
F4U testing occurred aboard USS Altamaha on 1 March 1944. He made two
JATO assisted launches that day. According to him, as far as he could
tell, on a straight deck run, the JATO packs added little to the
process. The concept was investigated a means to increase the number
of planes on escort carriers thru shortening the deck space needed for
launch by increasing take off speed. The thrust developed by an R2800
at full power (compared to the Wildcat's R1830) was not particularly
enhanced by the JATO units during takeoff. The place where the
difference in power had its effect was after the airplane had already
left the ship. It was also discovered that, when mixed with salt
spray, the exhaust from the JATO units covered everything with an ugly
white glop that was hard to remove, especially from the windscreens and
canopies of the aircraft parked on the stern. There was some suspicion
that this glop might also have some corrosive effect on aircraft and
equipment if not removed immediately. Bottom line was that it was an
interesting idea, but not terribly practical; in the end, catapults
already in use seemed a much better idea. JATO units on F4U's, nor
any other USN WWII fighters, were not implemented in the Fleet during
the war.
Regards,
Rich
Corsairs over Ct, James Lloyd Home Built 2 April 26th 05 11:44 PM
Corsairs over Ct. James Lloyd Home Built 1 April 25th 05 03:06 PM
Canadian FAA Corsairs - August 1945 William Burns Military Aviation 2 June 2nd 04 06:56 PM
Canadian FAA Corsairs - August 1945 William Burns Naval Aviation 2 June 2nd 04 06:56 PM
Navalized P-38 Lightning? Steven Wagner Military Aviation 51 February 28th 04 11:18 PM
