Martinsyde G.100
Old September 21st 20, 07:04 AM posted to alt.binaries.pictures.aviation
Miloch
Default Martinsyde G.100
https://en.wikipedia.org/wiki/Martinsyde_G.100
The Martinsyde G.100 "Elephant" and the G.102 were British fighter bomber
aircraft of the First World War built by Martinsyde. The type gained the name
"Elephant" from its relatively large size and lack of manoeuvrability. The G.102
differed from the G.100 only in having a more powerful engine.
Design and development
An unusually large aircraft by contemporary standards for a single-seater, the
Elephant two-bay equal span staggered biplane was designed by A A Fletcher of
the Martinsyde Company, a prototype powered by a 120 hp Austro-Daimler engine
entering test in the autumn of 1915.
The initial production version, the G.100, was powered by a 120h p six-cylinder
Beardmore engine and was armed with a single 0.303 in drum-fed Lewis Gun mounted
above the centre section. This was later augmented by a similar weapon
bracket-mounted to the port fuselage side behind the cockpit).
The G.100 was gradually succeeded by the G.102 with a 160 hp Beardmore engine.
Maximum speed of the 160 hp aircraft was 108 mph (174 km/h) at sea level,
falling to 100 mph (160 km/h) at 10,000 ft; it had a maximum ceiling of 14,000
ft (4,300 m).
Operational use
The G.100 was built originally as a long-range, single-seat fighter and escort
machine but on the basis of its size and weight was reclassified as a day
bomber.
Deliveries to the RFC commenced in mid-1916, a total of 270 being manufactured.
The G.100 and G.102 Elephants were used in France and the Middle East, although
only No. 27 Squadron, RFC was completely equipped with this type.
While not particularly successful as a fighter owing to its poor agility by
comparison other fighters of the times, the Elephant performed a useful service
in long-range bombing, carrying up to a 260 lb (120 kg) bomb load. It
successfully performed this role from the summer of 1916 through to late 1917.
It was also used for long-range photo reconnaissance, where stability and
endurance were required (the type was capable of a five-and-a-half-hour flight).
Variants
Martinsyde G.100 : Single-seat fighter-scout, bomber and reconnaissance biplane,
powered by a 120 hp (89 kW) Beardmore piston engine. 100 built.
Martinsyde G.102 : Single-seat fighter-scout, bomber and reconnaissance biplane,
powered by a 160 hp (119 kW) Beardmore piston engine. 171 built
Specifications (G.100)
General characteristics
Crew: 1
Length: 26 ft 6 in (8.08 m)
Wingspan: 38 ft 0 in (11.58 m)
Height: 9 ft 8 in (2.95 m)
Wing area: 456 sq ft (42.4 m2)
Empty weight: 1,795 lb (814 kg)
Gross weight: 2,424 lb (1,100 kg)
Powerplant: 1 × Beardmore 120 hp 6-cylinder water-cooled in-line piston engine,
120 hp (89 kW)
Propellers: 2-bladed fixed-pitch propeller
Performance
Maximum speed: 96 mph (154 km/h, 83 kn)
Range: 450 mi (720 km, 390 nmi)
Endurance: 4 hours 30 minutes
Service ceiling: 14,000 ft (4,300 m)
Time to altitude: 10,000 ft (3,048 m) in 16 minutes with Beardmore 160 hp engine
Armament
Guns:
1 × 0.303 in Lewis gun mounted above upper wing centre section
1 × Lewis gun mounted fixed aft of the cockpit pointing rearwards
Bombs:
260 lb (120 kg) bombload
UK1 A4002 Martinsyde Elephant Waddington JMBruceColl.jpg Joseph Testagrose Aviation Photos 0 October 26th 13 06:39 AM
UK1 D4256 Martinsyde Buzzard.jpg Joseph Testagrose Aviation Photos 0 March 25th 11 11:47 PM
