help with an ILEC SB-9
Old May 5th 21, 01:22 PM posted to rec.aviation.soaring
Default help with an ILEC SB-9
I bought a glider which had been in storage for some time. It has an ILEC SB-9 vario which does not appear to be functioning.
When I power on the vario, the needle climbs to the one knot up position and stays there continually while beeping. It does this regardless of which position the mode switch is set to.
Gently applying pressure or suction to the pitot causes the other vario (Cambridge 302) to respond, but the ILEC does not respond at all.
I have removed the old rechargeable 9v battery from the ILEC with no change in behavior.
Are there troubleshooting steps I should attempt before I remove this vario?
Matt
Old May 5th 21, 03:00 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Matt
I searched for "ILEC SB-9 manual" and read it to find this... Have you followed the maintenance procedure and replaced the battery?
"Maintenance
SB-9 adjustments
Emergency accumulator
The emergency battery is a NiCd accumulator and should be renewed after 5 years. Only use a type
like VARTA TR 7/8 for this purpose.
CAUTION: Never use non rechargeable primary batteries, they may blow up when being charged.
The lifetime of this accumulator will be extended, when being discharged twice a year. Therefore we
recommend the SB-9 to be switched to the emergency mode (RES) for at least 10 hours, main battery
off, to discharge ist accumulator. DonĀ“t forget charging afterwards."
Also "The SB-9 is switched off automatically when the emergency battery voltage falls below 7.7V, to prevent overdischarging and damaging this accumulator." so it won't work with it removed - your problem.
Replacement batteries: https://www.ebay.ca/itm/123798119902...8AAOSw3jZc-qaJ and probably elsewhere
Dan
Old May 5th 21, 04:56 PM posted to rec.aviation.soaring
I momentarily connected a non-rechargeable 9v battery with no change in behavior.
Old May 6th 21, 12:17 PM posted to rec.aviation.soaring
Dave Nadler
Contact: ILEC GmbH
FS: ILEC SN-10 AJM Soaring 2 June 19th 14 03:45 AM
Ilec MCU Mark Jardini Soaring 1 July 18th 08 11:21 PM
FS: Ilec SB-9 (US) [email protected] Soaring 0 December 2nd 06 11:44 AM
FS - ILEC SB-7 Jim Hendrix Soaring 0 August 5th 05 09:08 PM
FS-Ilec SC-7 Glen Kelley Soaring 0 March 22nd 05 03:50 PM
