Navy Performs Maximum Range Test of Boeing SLAM-ER
Old June 2nd 05, 03:03 AM
KDR
Default Navy Performs Maximum Range Test of Boeing SLAM-ER
Andy Tompkins wrote:
http://i-newswire.com/pr21007.html
[snip]
The maximum-range test was from an altitude of 40,000 feet from a U.S.
Navy F/A-18B more than 170 miles ( 150 nm ) from a mobile ship target.
After being released, the SLAM-ER twice received updated target
information, changed its course and directly hit the target. The
SLAM-ER is the only weapon in the Navy's arsenal capable of hitting a
moving target from standoff outside area defense ranges.
[snip]
Any info about how far & high the F/A-18B was from the target when the
missile twice received updated target information from the launch
aircraft?
Old June 2nd 05, 04:09 AM
leadfoot
"KDR" wrote in message
[snip]
[snip]
aircraft?
Who said it received the update from the launch aircraft?
Old June 2nd 05, 04:54 AM
KDR
There's no mention about any other aircraft involved in the 150NM-shot
test. Whether the launch aircraft sent target info updates to the
missile or not, what I want to know is this: the maximum possible
distance between the controlling aircraft and SLAM-ER.
Old June 2nd 05, 07:49 AM
TOliver
The links are (as in most other similar examples) "Line of Sight", with
range solutions depending on launch and flight profiles. From what has been
the limited info available, the context and inferences which may be drawn,
it's likely that the corrections were supplied by another a/c (which after
all is sort of the point of the program).
TMO
Old June 4th 05, 01:44 PM
John Doe
[snip]
[snip]
aircraft?
Where does it say the updated information came from the launch aircraft?
Old June 13th 05, 04:27 AM
Kyle
The answer to your question is classified. I wouldn't be expecting an answer
from anyone involved. And there is no one answer. As stated before, it
depends on a lot of factors including luck. Having said that, the launch
aircraft certainly could have guided the weapon and it would not have to do
it at 150 NM. By following the weapon inbound, the range would be less than
150 NM upon guidance. It could have also been done by another aircraft
equipped with a data link pod at some range to the weapon.
Old June 13th 05, 08:43 AM
Fred J. McCall
"KDR" wrote:
:... what I want to know is this: the maximum possible
:distance between the controlling aircraft and SLAM-ER.
Classified.
"Millions for defense, but not one cent for tribute."
-- Charles Pinckney
Old June 13th 05, 08:56 AM
KDR
If the launch or other aircraft must maintain line of sight with
SLAM-ER throughout the missile's flight then it surely it cannot be
called an "over-the-horizon" weapon?
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 03:39 AM
