ELT Antenna
Old October 31st 04, 04:02 AM
Gary
Default ELT Antenna
Hello;
I am in the finishing stages of building a LIVP and realize that I have
forgotten to allow for the elt. What antenna that would be
suitable to place in the tail area (where the top section is
fiberglass). Getting a ground plane will be difficult. Is there an
alternative way to duplicate the effect of a ground plane? Is there any
issue with proximity to com antennas? I have a wire whip 2nd
antenna that is in that section as well.
Gary Rodgers
Old October 31st 04, 04:38 AM
UltraJohn
A lot of the C-150's I've flown just had the ELT with attached whip antenna
mounted to the side of the baggage area. Nothing fancy!
Usually it will be a satelite that will pick up the signal and get earth
bound rescuers to the general area anyway so your not too concerned about
line of sight.
John
Gary wrote:
Hello;
Gary Rodgers
Old October 31st 04, 08:52 PM
Gary
Thanks for the reply. The issue really is the fact that carbon fiber (lower
part of the tail) is not as good a ground plane as the metal of a Cessna.
Should I be using the 'Z' type com antenna that is for building into the
vertical stabalizer? Seems that type doesn't have the same requirement for
a ground plane.
Gary
"UltraJohn" wrote in message
hlink.net...
antenna
line of sight.
John
Gary wrote:
Hello;
Gary Rodgers
Old November 1st 04, 06:43 AM
Flyboy Chris
Just a note for all to keep in mind. Beginning in Jan 2009, the
satellites will no longer monitor 121.5/243.0 MHz for distress beacons.
Check out the COSPAS-SARSAT home page
(http://www.cospas-sarsat.org/MainPages/indexEnglish.htm), the FAA Home
Page (http://www.faa.gov/), or NOAA's SARSAT Page
(http://www.sarsat.noaa.gov/)
....zoom
(lower
Cessna.
requirement for
a ground plane.
Gary
hlink.net...
antenna
earth
about
line of sight.
John
Gary wrote:
Hello;
I have
an
there any
Gary Rodgers
Old November 2nd 04, 06:48 PM
A j-pole antenna has a built in ground plane and works very well. Just
google on jpole or j-pole antenna. Or maybe a full wave loop if you
have the area for one. A dipole also can be used with up to a 90 degree
angle in the center. Just some ideas. Contact a local ham radio club. A
dipole with a 90 degree angle is fairly omni-directional and easy to
build.
Have the antenna checked BEFORE testing for SWR with an MFJ antenna
analyzer from a local ham club. The ARRL antenna handook for VHF is an
excellent resource.
I would definitely MAKE SURE the antenna cannot come loose. Use 50 ohm
coax to feed if that is what impedence the radio expects.
Rob
Old November 3rd 04, 03:13 AM
Jim Weir
Did you really read what the guy had to say? Do you know that a j-pole at 121.5
is longer than a B-17's rudder assembly? Do you understand that you have to
radiate equally efficiently at both the fundamental and second (NOT third)
harmonic?
Did you read that he has only a small amount of fiberglass in the tail, and that
most of it is carbon fiber? Did you read that there is another com antenna in
that same location?
I read it and concluded that they guy didn't have a chance in hell of putting
his ELT antenna in the tailfeathers, but waited around to see if somebody that
knew what they were talking about came up with a clever idea...I don't claim to
have cornered the market on clever.
Do you understand that a j-pole does NOT have a built-in ground plane, but is a
matched half wave radiator? Why do you limit the dipole to a 90 degree angle?
If SWR is all you are concerned with, I can give you an antenna that is good
from DC to 20 GHz.. It is called a 51 ohm resistor.
Jim (still waiting for clever) Weir
-A j-pole antenna has a built in ground plane and works very well. Just
-google on jpole or j-pole antenna. Or maybe a full wave loop if you
-have the area for one. A dipole also can be used with up to a 90 degree
-angle in the center. Just some ideas. Contact a local ham radio club. A
-dipole with a 90 degree angle is fairly omni-directional and easy to
-build.
-Have the antenna checked BEFORE testing for SWR with an MFJ antenna
-analyzer from a local ham club. The ARRL antenna handook for VHF is an
-excellent resource.
-I would definitely MAKE SURE the antenna cannot come loose. Use 50 ohm
-coax to feed if that is what impedence the radio expects.
-Rob
http://www.rst-engr.com
Old November 3rd 04, 04:12 AM
UltraJohn
121.5
to radiate equally efficiently at both the fundamental and second (NOT
third) harmonic?
I still contend what I said earlier.
Most older C-150's that were retrofited with an ELT use an ELT with a whip
(1/4 wave) fixed to the ELT with no groundplane. Would I recommend this for
a com radio? no! but it does work in thousands of C-150's (and probably
others I'm just familiar with 150's). anyway KISS is the best.
John
Old November 3rd 04, 07:32 AM
Jim Weir
And I don't disagree with you. For this guy, in this situation, an ELT with the
whip mounted on the ELT is probably the optimum solution if his airworthiness
inspector will let him get away with it.
I'm constantly amazed at the number of calls I get asking whether an ELT antenna
should be mounted horizontal or vertical polarization. The stock answer is that
if you can guarantee me the orientation of the airframe if you really need the
services of the ELT, I can give you that advice.
UltraJohn
-I still contend what I said earlier.
-Most older C-150's that were retrofited with an ELT use an ELT with a whip
-(1/4 wave) fixed to the ELT with no groundplane.
Old November 3rd 04, 03:22 PM
Cy Galley
I believe that the C-150 has a metal skin that acts like a ground plane
automatically.
link.net...
at
121.5
have
third) harmonic?
for
John
Old November 3rd 04, 05:18 PM
Jim Weir
You weren't reading what he was saying, Cy. In the very early days of ELTs,
then didn't have to have external antennas. The contemplation is that whatever
tore the airplane up would have torn it up enough that the ELT would have been
exposed to the point where an antenna connected directly to the ELT body itself
sufficed for the installation. No external antenna.
I haven't seen an approved design like this for thirty years or so, but at one
time, it was all the rage. One manufacturer actually had a steel tape measure
segment spring loaded to uncoil at some g load and act as the antenna.
"Cy Galley"
-I believe that the C-150 has a metal skin that acts like a ground plane
-automatically.
-"UltraJohn" wrote in message
hlink.net...
- Most older C-150's that were retrofited with an ELT use an ELT with a whip
- (1/4 wave) fixed to the ELT with no groundplane. Would I recommend this
-for
- a com radio? no! but it does work in thousands of C-150's (and probably
- others I'm just familiar with 150's). anyway KISS is the best.
- John
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 07:59 PM
Another antenna question David Wilson Home Built 7 August 12th 04 11:04 PM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 01:27 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 04:27 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 06:34 PM
