Shinn brakes return springs
Old June 16th 05, 11:39 PM
Michael Horowitz
Default Shinn brakes return springs
Anyone got a favorite technique for installing same?
Old June 19th 05, 08:48 PM
Use plenty of expletives, have a good grip, forearm and biceps;
needlenose pliars equal to the task -- I cover the jaws with duct-tape
so as not to burr the spring hooks; and infinite patience. Sometimes
you can pull a string or wire or thong attached to the spring hook.
I don't remember the details but grit my teeth a little for a lot of
effort with so little return on the investment --- i. e., the brakes
are just a degree above useless and will get you into trouble if one
wheel has much better brakes than the other one.
Hint: they won't stop you for a static run-up.
I had my first ground loop recently after replacing one actuator cable.
The cable stretched so that the heel brake bottomed out and gave the
other brake on the other wheel all the authority. No wing-tip damage,
though, just rubber left on the runway and the ego from razzing by
onlookers.
FL 2004 - Brakes will not release James Simulators 3 March 27th 05 03:23 AM
Shinn brake lining/riveting/counterboring depth? Michael Horowitz Owning 0 August 29th 04 04:12 PM
Shinn brake linings - bonding vice riveting Michael Horowitz Owning 0 July 12th 04 04:47 PM
McCaully wheels & brakes available Roger Long Owning 0 March 4th 04 02:19 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
