New Cheap Rugged Turbine
Old June 23rd 05, 05:56 AM
Default New Cheap Rugged Turbine
A new turbine has been announced which is claimed to have unprecedented
low cost and ruggedness:
http://www.theengineer.co.uk/Article...n+turbines.htm
http://www.swri.edu/4org/d18/mechflu...rb/radflow.htm
How significant is this announcement? How low-cost is low-cost? How
rugged is rugged?
What is the tradeoff to this design? Lower energy efficiency?
What new applications will it enable or make practical? Turbine
lawn-mowers? Turbine-powered bicycles? New personal aircraft? Moller
SkyCar? Helmet-mounted turbine helicopter blades?
Comments plz?
(Btw, just as an aside -- what is a 'nanotechnology gas turbine'
anyway? Is that one of those experimental dime-sized turbines etched
from a silicon wafer that can be used to power a laptop or PDA?)
Old June 23rd 05, 07:34 AM
Chad Irby
In article .com,
rugged is rugged?
You might note that "fuel efficient" was the one phrase they didn't
manage to use in either article.
Probably a lot of things, but I wouldn't hold out for a very long-range
transport application.
I don't have a lifestyle.
I have a lifeCSS.
Old June 23rd 05, 11:05 AM
Dikkie Dik
rugged is rugged?
I like the idea, although I wonder how the turbine works. Does it work,
like spinning fireworks, by slinging the air in a radial way? In that
case, it is probably less effective than a conventional turbine. Also,
the combustion part seems a bit "wasted area" to me (I know you need
combustion, but you would rather not have placed it on the disc). I
think you run into trouble with this design if you make it too large,
for both rotating-mass reasons and turbine earodynamical reasons.
Still, combining all the rotating parts of a jet engine into one is
something brilliant.
One of the first applications that springs to mind is model aircraft.
Simplicity is very important there and fuel efficiency comes second. You
could build real turbine model helicopters for a reasonable price.
Comments plz?
I do not know what the engine will do at extremely low Reynolds numbers,
although I think you can construct the disc in such a fashion that the
flow has no choice but to "follow the lines". I don't have a the
faintest idea how effective it would be at a sub-milimeter scale.
You could build tiny maintenance robots with it (to revise or check a
conventional turbine ), but I'm afraid the military would be
interested first to build deadly bugs.
Best regards
Old June 23rd 05, 01:54 PM
Peter Stickney
unprecedented low cost and ruggedness:
rugged is rugged?
work, like spinning fireworks, by slinging the air in a radial way?
In that case, it is probably less effective than a conventional
turbine. Also, the combustion part seems a bit "wasted area" to me
(I know you need combustion, but you would rather not have placed it
on the disc). I think you run into trouble with this design if you
make it too large, for both rotating-mass reasons and turbine
earodynamical reasons. Still, combining all the rotating parts of a
jet engine into one is something brilliant.
It's a radial inflow turbine - basically a centrifugal compressor
running backwards. von Ohain's original jet engine prototype used a
similar arrangement. But it worked so well that it was dropped like
a radioactive potato.
(See, in this case, the Germans _sere_ first!)
Moller SkyCar? Helmet-mounted turbine helicopter blades?
aircraft. Simplicity is very important there and fuel efficiency
comes second. You could build real turbine model helicopters for a
reasonable price.
Other than the Gee-Whiz factor, what would be the advantage? Model
engines are so small that there won't be much, if any, weight
savings, (Most of the weight will be the engine carcase and you're
going to need a heftier gearbox), it'll be expensive, and who knows
how long it will last?
Comments plz?
etched from a silicon wafer that can be used to power a laptop or
PDA?)
Basically. Feed it a few drops of alcohol, and off you go. Well -
once you can get a reasonable amount of power from it. We're not
there yet.
Pete Stickney
Java Man knew nothing about coffee.
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
Rick Stitt, Joe Rinke, Rinke Aerospace, BJ Schram, Mini 500, Turbine, Helicopter, Kit TurbineMini Richard Rotorcraft 2 January 24th 04 01:15 AM
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit TurbineMini Richard Rotorcraft 0 January 15th 04 11:48 PM
TRUTH OF THE MINI-500 TURBINE CONVERSION Dennis Chitwood Rotorcraft 10 January 7th 04 05:33 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
