50 degrees rich of peak
Old June 24th 05, 08:50 PM
lardsoup
Default 50 degrees rich of peak
Ok. Just want to see if I have this correct. When leaning using an EGT
gauge the 172R POH says to lean untill the EGT needle peaks then enrich to
50 degrees F rich of peak EGT.
So the EGT temperature will be 50 degrees less than the peak reading.
Right?
Old June 24th 05, 09:12 PM
Michael
Right. Your understanding of what 50 degrees rich of peak means is
correct.
Whether that's a good way to operate the engine is highly debatable.
Michael
Peter R.
Right?
Slowly roll out the mixture lever watching the EGT gauge. When the
temperature on the EGT gauge peaks and begins to fall, roll in the mixture
lever until the temperature peaks, then keep rolling it inward until the
temperature needle falls 50 degrees below (or less than) the peak
temperature you witnessed.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
Old June 24th 05, 09:49 PM
Depends on if you want best power or best range. 50 degrees is for best
range, and 75 for best power if you don't want to crisp your valves.
Think of the heat in the valve section....excess fuel cools the valves
and that is what the EGT is doing for you.
Old June 24th 05, 10:49 PM
Thomas Borchert
Lardsoup,
go to www.avweb.com and search for columns by John Deakin on engine
management. Read them all. They will answer your question - and tell
you much more that's really good to know. Fun to read, too.
Thomas Borchert (EDDH)
Old June 24th 05, 10:57 PM
Mortimer Schnerd, RN
Right?
Yes.
VE
Old June 24th 05, 11:36 PM
lardsoup,
You are correct in the interpretation, however, do not run the engine
at that power setting, it's about the worst possible for it.
As stated above, read John Deakin's columns in AVweb about what's going
on inside the engine. Either run it about 100 degrees rich of peak or
slightly lean of peak, although, thankfully on the little GA engines so
long as you are at 65% power or less you can't hurt them, the temps and
pressures don't get high enough.
All the best,
Rick
Old June 24th 05, 11:39 PM
selway,
You might want to read Deakin's articles on engine ops in AVweb.
Crisping or burning the valves is an oft repeated, but untrue
statement. It is without any data to support it.
All the best,
Rick
Old June 25th 05, 01:35 AM
Matt Barrow
"Michael" wrote in message
correct.
The actual and extensive data shows it's about the worst place you can
operate. That's in terms of both CHT and cylinder pressures.
Old June 25th 05, 02:54 AM
Peter R.
The OP cannot be faulted for leaning as per the POH. The late model C172
R and S model POH (page 4-26) recommends 50 degrees lean of peak. I would
suspect the OP is simply following the POH recommendation.
And before you flame me for simply pointing out this fact, keep in mind
that I am a 60-80 degree lean-of-peak leaner. :-)
Peter
Headwinds, always Paul kgyy Piloting 36 June 9th 05 02:05 AM
Lycoming's views on best economy settings [email protected] Piloting 37 July 8th 04 05:00 PM
Constant speed props GE Piloting 68 July 3rd 04 05:08 AM
Lean of Peak Test Flight Roger Long Piloting 0 April 22nd 04 11:13 AM
Thanks for the Spins Rich David B. Cole Aerobatics 17 October 26th 03 09:37 AM
