Wish us luck!
Old June 25th 05, 04:20 AM
George Patterson
Ok!
George Patterson
If you're going through Hell, keep on going.
Old June 25th 05, 04:22 AM
Darrel Toepfer
Jim Burns wrote:
Well, tomorrow morning our Aztec goes in for it's 39th annual. Gosh, you'd
think after 39 times, they'd have just about everything fixed on it!!
This will be a fully owner assisted annual. All three of us took a few days
off from work and will have our screwdrivers totally worn out by the time
everything is back together.
40th for our C172F, finished this week after 3 weeks of downtime due to
scheduling conflicts with the A&I. New rotors, brake pads and scat
hoses, tachs low by 50 rpm. Whats the deal with the CO detection
thingie, we've never had that before? I've put a CO detector in every
plane we've owned though...
Old June 25th 05, 06:13 AM
Jim Burns
Default Wish us luck!
I'm just hoping the engines are fine, other than a nagging oil weep on the
right engine, they sure seem healthy. Everything else should be fairly
minor as we've been doing extensive preventative maintenance and minor
upgrades ever since we bought it.
I'll keep good notes and report in with the results.
Jim Burns
Old June 25th 05, 05:48 PM
John Clonts
"Darrel Toepfer" wrote in message ...
40th for our C172F, finished this week after 3 weeks of downtime due to scheduling conflicts with the A&I.
New rotors, brake pads and scat hoses, tachs low by 50 rpm. Whats the deal with the CO detection thingie,
we've never had that before? I've put a CO detector in every plane we've owned though...
What do you mean, "Whats the deal with the CO detection thingie?" You've never had what before?
Cheers,
John Clonts
Temple, Texas
N7NZ
Old June 25th 05, 07:05 PM
Darrel Toepfer
IA required our plane to be run at different angles to the wind while he
sniffed for CO from various vents with cabin heat on and off...
Old June 25th 05, 10:31 PM
John Clonts
IA required our plane to be run at different angles to the wind while he sniffed for CO from various vents
Ok, thanks. I wasn't aware of that particular inspection protocol....
Cheers,
John Clonts
Temple, Texas
N7NZ
Old June 25th 05, 11:25 PM
Jay Honeck
Good luck, Jim. I feel your (potential) pain...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old June 26th 05, 02:36 AM
Jim Burns
Top and bottom cowls, nosebowls, rear nacelle panels, spinners, and all
inspection panels pulled. Tomorrow the interior comes out. So far all
we've noticed is that the left engine needs a new alternator belt and some
residual grease on one blade of the left prop (beneath the spinner), hope
that isn't a problem.
Old June 26th 05, 01:56 PM
Mike Spera
The interior comes out? What do you pull out? Every annual?
Old June 26th 05, 02:20 PM
Mike Spera
Seats, to access floor, then floor panels and side panels to access cables,
pulleys, hyd. lines, flap accuator ect.
Jim,
Is there really any of that stuff in the side panels? Just curious. My
Cherokee has nothing but wiring in the side panels. All my cables are in
the central tunnel and under the hinged back seat deck. So, all I have
to do for inspection is lift the seat deck, unsnap the tunnel carpet,
and remove 2 small inspection plates.
I have not peered into an Aztec lately.
Leaving the community David Brooks Instrument Flight Rules 556 November 30th 04 09:08 PM
Leaving the community David Brooks Piloting 770 November 29th 04 01:07 AM
Good AI backup, wish me luck Robert M. Gary Instrument Flight Rules 29 March 1st 04 06:36 PM
Winston Churchill As Anthrax Bomber Krztalizer Military Aviation 28 February 2nd 04 04:33 AM
Good Luck, Jim! Rich S. Home Built 203 November 5th 03 12:46 AM
