New G-1000 182 & Cirrus SR-22 GTS
Old June 26th 05, 04:00 PM
Dan Luke
Default New G-1000 182 & Cirrus SR-22 GTS
Cessna and Cirrus brought one of each to the Angel Flight fly-in at PNS
yesterday, and I got the sales pitch from each rep. No test flights,
alas.
Both are highly desirable airplanes, of course, but I was surprised at
how closely I rated them as a potential buyer:
* Speed: Cirrus wins big: 40+ KTAS faster. The Cessna rep. claimed 135
for the Skylane, which seems a bit pokey for an airframe that has
supposedly had an extensive aerodynamic cleanup.
* Cost: 182 wins big: ~$100k lower sticker price and $3.5k insurance
premium vs. $8k(!) for the SR-22. The Cirrus guy said mine might be as
much as $1.5k lower since I have 1,000 hours, an instrument rating and
600+ hours of retract time.
* Useful load: Slight edge to the 182; 1213 lbs. vs. 1150 lbs.
* ROC: Cirrus wins big; 1,400 fpm vs. 923 fpm.
* Takeoff/Landing performance: 182 wins big. Although they are pretty
close on takeoff, the Skylane is 1,000' better landing over a 50'
obstacle.
* Interior: Very slight edge to Cirrus. It's a bit roomier, and the
accessibility of controls and switches without a yoke in the way is very
good. The 182 was very nice inside, too. The redesigned instrument
panel puts the switches easily to hand, and they have nice big handles
and labels. The no-nonsense metal panel is a great improvement over the
old plastic crap - overall, the interior gives the impression of utility
and durability. With the seat at max. vertical adjustment, the view
over the glare shield seems a bit better than in older Skylanes.
* Avionics: A tie. The displays looked terrific in full daylight. The
182 does not have XM weather on the Garmin MFD yet, but Cessna says it
will be added at no cost when it's available. For now, 182s are
delivered wit a B/K KAP-140 autopilot; later models will have a new
Garmin ap built into the G-1000.
So if I were of a mind to plunk down a few hundred large for a new
piston single, I might have trouble choosing between these two very nice
rides. The SR-22 is more airplane, but it's a lot more money, too.
Cessna has done a fine job modernizing the 182, IMO, and I'd be very
happy to own one.
Dan
C172RG at BFM
Old June 26th 05, 04:31 PM
Jose
happy to own one.
Interesting comparison, but the two aircraft being compared just
"happend to be" being compared with each other. Were I to be making a
choice of aircraft, I might pick a number (say, the price of the Cirrus)
and see how much airplane that would buy me from other companies. What
does Cessna offer for $100K more than the 182 pictured? (A citation?
Jose
r.a.owning snipped; I don't follow the group
You may not get what you pay for, but you sure as hell pay for what you get.
Old June 26th 05, 06:37 PM
Dan Luke
Cirrus) and see how much airplane that would buy me from other
companies.
A Lancair or a Mooney would be pretty close.
What does Cessna offer for $100K more than the 182 pictured?
A 206. Really a different mission aircraft; it's a 6-seat heavy hauler.
(A citation?
Ha! In our dreams.
Dan
C172RG at BFM
Old June 26th 05, 07:21 PM
Andrew Gideon
Dan Luke wrote:
A 206.Â*Â*ReallyÂ*aÂ*differentÂ*missionÂ*aircraft;Â* it'sÂ*aÂ*6-seatÂ*heavyÂ*hauler.
But if you frame the question this way, it's clear that Cessna offers "more
airplane" for the same dollars. But it also begs the question of a
comparison between the SR-22 and the 206 (ie. speed, load, etc.).
- Andrew
Old June 26th 05, 07:38 PM
Charles Oppermann
Both are highly desirable airplanes, of course, but I was surprised at how
But it's still the same basic airframe. There is only so much you can do.
The Cirrus has a composite body that is lighter and much more aerodynamic
with less drag.
Don't worry as much about a airspeed number. Rather, factor it in with fuel
burn and compare the cost of a 1 hour trip, a 2 hour trip and a 4 hour trip.
Going 20% faster isn't a bargin if your fuel burn goes up 50% - I'm not
saying that the Cirrus does that, just that you should take the true
airspeed value as a factor in other performance figures.
I regularly get 132-135 KTAS in my C182S above 8,000feet (solo). The C182T
(non-turbo) should do 2-3 knots better under same conditions.
Also check on the availability of maintenence. When I was comparing the
SR-20 vs. a C182S a few years ago, Cirrus was new and would have been more
expensive to maintain.
I'm often bumping up into the max useful load on my C182S. Those 63 pounds
might come in handy!
obstacle.
Put you can fly a Skylane with those huge flaps and high wing into the
shortest and roughest of strips.
good. The 182 was very nice inside, too. The redesigned instrument panel
puts the switches easily to hand, and they have nice big handles and
labels. The no-nonsense metal panel is a great improvement over the old
plastic crap - overall, the interior gives the impression of utility and
durability. With the seat at max. vertical adjustment, the view over the
It's better view from the Cirrus for everyone, but that generally means it's
hotter in the summer - might be an important factor depending on where you
live. The Skylane is easier to get in and out of for everyone.
From a comfort standpoint, I wonder which one is noiser - does the composite
airframe of the Cirrus help with that at all? Might be a consideration.
will be added at no cost when it's available. For now, 182s are delivered
wit a B/K KAP-140 autopilot; later models will have a new Garmin ap built
into the G-1000.
Right now, I think the Garmin G1000 is going to be better supported than the
system in the Cirrus. The KAP-140 is an excellent 3-axis autopilot.
So if I were of a mind to plunk down a few hundred large for a new piston
single, I might have trouble choosing between these two very nice rides.
The SR-22 is more airplane, but it's a lot more money, too. Cessna has
done a fine job modernizing the 182, IMO, and I'd be very happy to own
one.
I'm sure you know this already, but it's not the initial cost, but the
operating and owning costs over time. Insurance will be lower and
maintenence might be cheaper with the Skylane.
Old June 26th 05, 07:44 PM
Blueskies
"Charles Oppermann" wrote in message ...
Both are highly desirable airplanes, of course, but I was surprised at how closely I rated them as a potential buyer:
* Speed: Cirrus wins big: 40+ KTAS faster. The Cessna rep. claimed 135 for the Skylane, which seems a bit pokey for
an airframe that has supposedly had an extensive aerodynamic cleanup.
But it's still the same basic airframe. There is only so much you can do. The Cirrus has a composite body that is
lighter and much more aerodynamic with less drag.
Don't worry as much about a airspeed number. Rather, factor it in with fuel burn and compare the cost of a 1 hour
trip, a 2 hour trip and a 4 hour trip. Going 20% faster isn't a bargin if your fuel burn goes up 50% - I'm not saying
that the Cirrus does that, just that you should take the true airspeed value as a factor in other performance figures.
I regularly get 132-135 KTAS in my C182S above 8,000feet (solo). The C182T (non-turbo) should do 2-3 knots better
So what are the fuel economy numbers for the 182 vs. Cirrus? Anticipate $5.00 gallon gas cost in the next 10 years...
Old June 26th 05, 09:25 PM
databus
delivered
built
into the G-1000.
And just what makes you think that ? I think you are confused, or maybe you
work for Garmin's marketing department.
Sure it is, if you don't like GPS roll steering, and you enjoy retesting
your static system every time you pull it out for repair or adjustment. The
KAP-140 is a two axis autopilot and the variant that comes in the 182 is two
axis with altitude preselect, not 3 axis. At least on the Cirrus the
autopilot's altitude preselect is on the PFD.
Old June 26th 05, 09:39 PM
karl gruber
The KAP-140 is a two axis autopilot.
Old June 26th 05, 10:30 PM
Jimmy B.
Last I heard, Cirrus still have the ~5000 hour airframe limitation. Has
this been lifted? Did you ask the Cirrus rep about it?
alas.
obstacle.
happy to own one.
Old June 26th 05, 10:47 PM
Dan Luke
135 for the Skylane, which seems a bit pokey for an airframe that has
do.
Yeah, but if 135 is all it'll do, they haven't done *anything*. My
buddy's old Skylane will do 133.
Less drag, yes. Lighter? No; the Cirrus is more than 300 lbs. heavier.
Composite construction is not lighter than aluminum.
with fuel burn and compare the cost of a 1 hour trip, a 2 hour trip
goes up 50% - I'm not saying that the Cirrus does that, just that you
figures.
The Cirrus wins. 180kt @ 16gph = ~11nm/gal vs.135kt @ 13 gph =
~10nm/gal. The Cirrus' advantage is even greater if you consider that
the engine/airframe cost/mile will be higher for the Skylane, because it
takes longer to get anywhere.
That's really what kills the 182 for me. I don't think I could stand to
buy a new airplane that's slower than my 172RG, even if it's only by a
little.
Yep. I'd have to fly to Destin, FL for warranty service on the Cirrus.
The local shop could work on a new Skylane for me.
[snip]
than the system in the Cirrus.
Why?
Roll, pitch, what's the 3rd axis?
[snip]
$100,00 invested over time is a lot of money.
Insurance will be lower and maintenence might be cheaper with the
Skylane.
Maybe.
Dan
C172RG at BFM
New G-1000 182 & Cirrus SR-22 GTS Dan Luke Owning 22 June 27th 05 08:18 PM
Iced up Cirrus crashes Dan Luke Piloting 136 February 16th 05 08:39 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Cirrus SR22 Purchase advice needed. C J Campbell Piloting 122 May 11th 04 12:30 AM
Cirrus attracting pilots with 'The Wrong Stuff'? Jay Honeck Piloting 73 May 1st 04 05:35 AM
