Spider in Archer Sump Drain
Old June 27th 05, 04:02 AM
Bob Chilcoat
Default Spider in Archer Sump Drain
Went out the the airport to carve up some air this afternoon in the Archer.
During the preflight, I noticed that I could get almost no flow from the
right sump drain. Was concerned that if the sump drain was blocked, there
might be stuff in the tank that could also block the fuel line or pickup.
However, I was only going up for an hour or so, had plenty of fuel in the
left tank, so I didn't use the right tank unless I was at least 2,000' AGL.
Shot three landings at three different airports, and had a nice time,
although with 100 degree temps and a density altitude of well over 2,000', I
was drenched after an hour of this. Oh well, an uncomfortable hour in the
air is better than any hour at work.
After parking the plane, one of my partners turned up, and I showed him the
drain cock problem. "Oh, yeah", he says. "I had that two days ago as I was
getting ready for an Angel Flight. Showed it to John (our A&P) who said it
was probably a spider building a nest inside the drain cock. I eventually
got a spider out in the drain jar". Sure enough, probing inside with a
piece of wire dislodged a lot of organic crap (but no spider), and the fuel
flows freely again. My partner had cleaned it out once, so there are
apparently more than one of these little *******s building nests. Where
else can they be crawling?
Bob (Chief Pilot, White Knuckle Airways)
Archer Tach Red Arc Greg Esres Owning 15 February 9th 05 09:28 AM
M20 Air/Oil separator Jay Honeck Owning 70 September 3rd 04 07:34 PM
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore Otis Willie Military Aviation 2 February 22nd 04 04:33 AM
Looking for user comment : Oil Sump Heater Javier Gorordo Owning 8 December 2nd 03 02:33 PM
sump drain cleaning Mike Noel Owning 15 August 15th 03 03:41 AM
