Long-EZ Bird Strike
Old June 29th 05, 03:09 AM
Default Long-EZ Bird Strike
Pretty incredible story:
http://www.ez.org/birdstrike.htm
Long-EZ pilot at 9,500 feet hit a bird, which shattered his prop, and the broken
prop took off almost all of one winglet. Full aileron was only able to keep the
wings level above 110 knots. Landed safely...sounds like a damn fine pilot.
Old June 29th 05, 03:25 AM
Jerry Springer
Hi Ron, I wonder what the evidence is that it was a bird strike? I don't
see any blood and guts anywhere. Of course with a pusher I suppose it
could have hit the prop and not left a trace? I hit a bird with the prop
of my Pacer one time and it was one nasty mess to clean up, the entire
airplane had some kind of mess on it. Regardless I am glad he was
able to land safely.
Jerry
Old June 29th 05, 03:52 AM
I noticed that, too. Something else could have gone through the blade, but I
don't know if a bolt or nut would do this kind of damage. The guy may have
cleaned it off already....
Old June 29th 05, 04:29 AM
Richard Isakson
"Ron Wanttaja" wrote ...
but I
have
"I heard something and I felt as if I was in a paint mixer. Then the
vibration stopped."
Looks and sounds like half the prop broke off and the other half shook off.
Rich
Old June 29th 05, 04:59 AM
Jerry Springer
I also wonder about the scratches on the tip of the blade in the white
paint area? the prop looks like it may be a ?Bernie Warnke? prop that
has Kevlar on the tip. I had one on my RV-6 that had Kevlar on the front
tip and about 1/2 of the back side of the prop. I loaned it to the late
Bill Benedict to try on his RV-4 and he lost about the same amount of
tip on one of the blades. Not both as this one is. He was able to shut
down and make a successful landing on a airport without any other
damage. There was speculation that the wood was rotten in that area (I
had about 500 hours on the prop) or that it was not tracked right when
he installed it. He admitted he did not track it.
Jerry
Old June 29th 05, 04:50 PM
Corky Scott
On Tue, 28 Jun 2005 18:52:56 -0700, Ron Wanttaja
Here's another couple of data points: The prop appears to be made
from a solid blank, not laminated from numerous strips.
I read a long time ago that the props on the EZ type aircraft run in
such turbulence that it's recommended they use wooden props only. The
turbulence is unavoidable in that it's the result of the prop passing
through the lift created by the trailing edge of the wing. There also
may be exhaust pulses to whap through as well. That's why the EZ's
have that characteristic buzz when they fly by. In fact all pushers
seem to sound that way.
Wooden props are supposed to **DAMPEN** vibration.
Interestingly, the only part of the information suggesting a bird
strike is the title. Nothing in the storyline claims that or suggests
it. It certainly isn't impossible for birds to be at 9,500, just a
lot less likely than closer to the ground. It isn't migration time...
Corky Scott
Old June 30th 05, 01:03 AM
Morgans
I could be wrong, but it looked to me to be made of thin laminations, about
1/8th" thick, instead of fewer thick ones.
Like I said, I could be wrong. Anyone know for sure?
Old June 30th 05, 02:33 AM
David Odum
Yes, those lines are laminations glue lines, not tree rings.
Here is a close-up pic from the site,
http://www.ez.org/images/prop1.jpg
My Ted Hendrickson prop is also made of thin laminations and is, I
have always thought, quite beautiful. Ted retired several years ago.
Lastly, as a Long EZ builder, owner, and flyer whose experience with
EZs dates back to the early Rutan days, my response to the scenario
and images depicted can be summed up in two words, Holy ****!
David Odum -- email: David at AirplaneZone dot com
Old June 30th 05, 03:59 PM
Corky Scott
On Wed, 29 Jun 2005 20:33:38 -0400, David Odum
You weren't aware of why pusher props make more noise than tractor
props? See below for the scientific explanation.
http://www.pfa.org.uk/pdf_docs/engin..._driven_la.pdf.
The relevant part is quoted below:
Pusher propellers can be particularly noisy as the turbulence from
upstream structure, e.g. The wing, impinge on the outer portions of
the blade. The Cessna 337 is particular poor design in this respect.
This aeroplane has a tractor propeller in the front and a pusher
propeller and the rear of the fuselage. Consequently the turbulence
from the front, tractor propeller and the wing and fuselage pass
through the rear pusher propeller causing relatively high noise
levels.
The Long EZ's do not have a tractor prop making turbulence of course,
but the wing is generating lift and the exhaust pulses must pass
through the prop and this causes vibration. I'm positive I've read
other treatsies on the subject, and I'm reasonably sure some of it
came from Rutan himself.
It doesn't make sense to you that a prop spinning in turbulent air
will vibrate?
Corky Scott
Old June 30th 05, 05:19 PM
Kevin O'Brien
On 2005-06-29 10:50:48 -0400, Corky Scott
Corky,
not questioning what you've read, but didn't Klaus Savier use to make
carbon fibre propellers, very hi-po indeed, for Longs? Coupled with a
pressure-recovery spinner and cowling of his own design, it was worth
quite a few knots.
I am working off dim memories here, but ISTR that Klaus had vibration
problems with an experimental (in the deepest sense of the word)
3-bladed prop and that he recommended 2-blades only for the EZ series
aircraft.
Indeed, here's one for sale on eBay:
http://cgi.ebay.com/ebaymotors/ws/eB...8722 584&rd=1
If
If the link breaks up:
http://snipurl.com/fxto
Hey, just checked his website and he still does make props:
http://lightspeedengineering.com/Tec...ties/Props.htm
But they have wood cores. I had thought he made all-compo ones. Guess not.
cheers
-=K=-
Rule #1: Don't hit anything big.
Tankers and strike packages (Was: EA-18G vs ES-3) [email protected] Naval Aviation 0 December 9th 04 12:11 PM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 04:02 PM
Hamas Leader Rantisi Killed by Israeli Strike on Car Dav1936531 Military Aviation 13 April 21st 04 08:04 PM
Joint Strike Fighter focus sparks concern Otis Willie Military Aviation 0 March 19th 04 10:19 PM
Simpy One of Many Stories of a Time Not So Long Ago Badwater Bill Home Built 40 March 16th 04 07:35 PM
